1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
03 F350 Stupid Door DING DING DING wont go off, what fuse to kill it?
Old 03-04-2009, 08:23 PM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
I have lubed the doors and the sensors must be bad. Im not replacing them, how do I just kill the dome light and the stupid DING DING DING, if the key is in the ignition? I couldnt find what fuse to use.
Old 03-04-2009, 11:33 PM
ageel's Avatar
ageel
ageel is offline
You can get rid of the ding easily. Remove the bottom plastic under the ignition switch (2 screws I think)and unplug the wire you find in there. Tape it up and tuck it in and your done with the noise.
Old 03-04-2009, 11:40 PM
c.f.moore's Avatar
c.f.moore
c.f.moore is offline
I don't know if it is the same in an '03, but you can program the dinger off. It's in the owners manual.
good luck
Old 03-05-2009, 01:57 AM
strlegal's Avatar
strlegal
strlegal is offline
good luck
yes you can shut off the seatbelt alarm in an 03.. But it wont do anything for the interior light if its coming on.
Old 03-06-2009, 04:27 PM
jeffbdeleeuw's Avatar
jeffbdeleeuw
jeffbdeleeuw is offline
I also have the same problem, the fuse is the #3. The only problem pulling it is you lose your dome light as well when you open the door.
Old 03-07-2009, 05:25 PM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Program the ding away and replace the dome light with a "dimmer" color, like blue or whatever. This place has the dome lights, this is the page with the correct lamp:
Festoon Bulb Specifications
DOUG5G
1983 - 2012 Ranger & B-Series
27
11-25-2014 03:49 PM
kind153
1997-2006 Expedition & Navigator
05-25-2014 06:19 PM
mtinsman
05-22-2013 08:27 PM
93nighthawk
Aerostar
06-19-2009 03:10 PM
RDC F250 7.3
34
12-07-2007 10:25 AM
Quick Reply: 03 F350 Stupid Door DING DING DING wont go off, what fuse to kill it?
