2008 f250 transmission problems? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-04-2009, 07:50 PM
Ripster Ripster is offline
Ripster is starting off with a positive reputation.
Hey everybody, I have a 08 f250 superduty with a automatic in her.( I call my truck her, I hope that does not offend anybody )Every so often but not all the time it seems like the transmission does not feel like it shifts like it should. Sometimes when you are going from 60kms to 80kms it kind of feels like it studders between 3rd and forth and then every once in awhile if you are driving at 50kms and give her a little shot it feels like she shifts down into a lower gear quicker then she should almost like it is spinning on ice, again this only happens once in awhile. I have her in the performance mode of my superchip and I have also installed a Banks cold air intake on her.One other note I have had the transmission flushed and new fluid put back in her. Please let me hear what you think....Thanks
Old 03-06-2009, 11:31 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputationhorsepuller has a superb reputation
Moved from 2011 F100 forum. Welcome and thanks for joining us at FTE!
Old 03-06-2009, 12:24 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
The terminology you use for your truck "Her" is correct. All vehicles are typically refered to as "Female"
If you feel or think you have a problem with the tranny you should bring it to the dealer as i am assuming it is still under warrany.
Old 03-06-2009, 04:19 PM
Did take it to the dealer and they said they could not find any codes, and of course it wasnt acting up when they looked at it. Has there been any issues with the solnoid packs on the trans?.....Thanks for responding by the way.......What do you think?
Old 03-06-2009, 07:18 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Could be an issue with the TCM Trans Control Module
Old 03-06-2009, 07:25 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
TCM may be a issue. Had something similar to that when my truck was new (600 miles). Replaced and been fine ever since.
You might try taking it back to a stock setting and see what that does for it.
Old 06-17-2009, 08:00 PM
wildbill6970 wildbill6970 is offline
wildbill6970 is starting off with a positive reputation.
Did you ever figure it out? My 08 f250 is doing the same thing and its stock.
Old 06-18-2009, 12:37 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Most vehicles, ships, tractors, trucks, etc. are referred to as she. I have always thought it was a complement to the female gender as they are being considered and thought of.
Old 06-19-2009, 05:42 AM
Ford dealer has my truck now they seem to think it might be a sticky solnoid on the tranny but not sure. It only does it once in a great while so of course it is haed to pin point. Are you having the same problems?
Old 01-03-2011, 10:20 PM
turbo229 turbo229 is offline
turbo229 is starting off with a positive reputation.
I have a bully dog triple dog tuner and my truck is doing the same thing. While in performance mode it shifts fine unless I really lay into the throttle from a stop. While in stock mode if I put a little torque on the transmission it starts jumping around in gears and shifts hard. Taking it to the dealer this week. 60,000 mile warranty and im sitting at 59,000.
Old 01-04-2011, 06:01 AM
senix's Avatar
Quote:
When you are bringing yours back to stock. Are you giving it enough time to re-learn?
Old 01-04-2011, 06:28 AM
How much time should I be giving it? Im probably not.
Old 01-04-2011, 06:32 AM
senix's Avatar
I'd run it from a stop thru all the gears several times so at least 10-20 miles I would think.
Maybe even from a stop, full throttle up to about 60 mph then let off, come to a stop then repeat a couple of times.
Old 01-04-2011, 06:36 AM
That is good advise, I will try that and post the results.
Old 01-04-2011, 06:38 AM
senix's Avatar
When I bought my Banks 6 gun they advised 3 WOT to 60 mph, then slow to 30 and hammer it back up to 60 mph.
They suggested that for level power setting.
I did that one time. Just running thru the gears as I suggested does the same thing.
ultimate sacrifce paid by this so called"dead beat dad" cjben General NON-Automotive Conversation 27 05-03-2016 11:41 PM
Transmission ? vmunoz_elec Expedition & Navigator 4 07-09-2014 10:13 AM
2006 F250 Super Duty Water in Oil, froze pheby 1999 to 2016 Super Duty 5 03-04-2014 04:56 PM
problems when on highway Ripster 6.4L Power Stroke Diesel 13 07-11-2009 09:56 AM
Automatic transmission Northern 1997 - 2003 F150 1 07-29-2007 07:46 PM
Tags
2008, 250, f250, ford, issues, job, problems, slip, sticky, tranny, transmishion, transmission, transmissions, trouble, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
