2008 f250 transmission problems?
Senix, you were correct. I just needed to give it time to adjust to the different tunes. I guess adjustments on the fly are not as fast as I thought. I spoke with a transmission specialist and he stated that in higher tunes pressure builds up in the lines and it takes a while for the transmission to adjust to the tunes. So you were spot on. Thanks a lot.
If you feel or think you have a problem with the tranny you should bring it to the dealer as i am assuming it is still under warranty.
_____________________________
<A href="http://www.micrositez.us/" target=_blank><ACRONYM title="Search Engine Optimization">SEO</ACRONYM>
cjben
27
05-03-2016 10:41 PM
2008, 250, f250, ford, issues, job, problems, slip, sticky, tranny, transmishion, transmission, transmissions, trouble, trucks
