Hi ,
Just did an oil change. New filter and 15 qts of non-synth. I went to start it, it ran for a few seconds then died. I trie to restart, it sputtered and died. Now it just cranks.
What's Up!?!?!
Thanks
Any oil leaks? Checking the level in the HPOP would be a good idea. You could have installed the filter without filling and it shouldn't do that.
How about the other basics? Plenty of fuel? Wait to start light come on like normal? Does the tach bounce while cranking? Does the oil pressure come up while cranking?
Did it pump all the oil out on the ground? Like possibly you double gasketed the oil filter and it just pumped the oil out past the flange on the filter?
yeah... I checked with a flashlight.. I've got about a gallon of oil in the driveway- no big deal. I guess I'll have to look closer tomorrow. Prolly something dumb.
