Pyrometer Install
#47
No, but DashBoss can. I saw your other post and hope Josh comes along. Do a Google search on DashBoss and you'll find it...
#48
I have had this truck awhile.. 6.0L D Excursion..
The autometer Pyro is the probe under a hose clamp on the turbo outlet.. The pyro quit working recently.
Should I buy the AutoMeter 5249 replacement and tap the manifold, or should I buy the 5247 replacement probe for double the cost.. It only lasted 2 yrs..
thanks in advance.. I do only light towing, and the motor is bullet proofed but otherwise stock with a mild street tune.
#49
I put a pyrometer in each manifold. For me its a huge benefit to see what each side is doing. I can tell if an injector starts over fueling or if I see the deltas get to far out of whack I know I need to have the injectors checked.
I have also been experimenting with Archoil in the oil and adding 2-stroke oil to the fuel mix, when I see the exhaust temps match almost exactly is when I know it is running at its best. I can honestly say I seen these 2 experiments make a difference. I use to run a delta of 40 to 50f and now I'm within 10f.
I had an injector over fuel a cylinder and take my last motor out, real peace of mind being able to monitor both sides.
#50
Not sure about any of the other OBD2 monitors that are on the market, some may have this capability too I dunno. But I do know that Scangauge does not. I hope this helps.
#51
For now, I can't find the replacement probe for less than 150$.. It has a small boss and a cone shape to be pressed into the hole drilled under the clamp. with short leads.. its funny, I call automater and they don't have a replacement for it.. I will pull it off and get a pic..
#52
big ole ford
16
03-07-2014 09:01 PM
deano-was-his-name-o
12-07-2008 12:33 PM
2000, 60, cat, delete, difference, f250, ford, install, installation, installing, make, pipe, powerstroke, probe, pyrometer
