Transmission Thermal Bypass Valve - Ford Truck Enthusiasts Forums
Old 03-04-2009, 07:52 AM
Jim Allen's Avatar
Jim Allen Jim Allen is offline
Jim Allen is starting off with a positive reputation.
As many of you know, most of our '04-08 F-150s have a temperature controlled bypass valve for the transmission that bypasses the coolers until the trans oil temp reaches about 185 degrees (this is according to some Ford documentation I just received). The unit looks like a square block and is in the cooler lines near where the engine meets the bellhousing. The idea behind it is to keep the trans from overcooling. Also, the torque converter does not lock up until trans oil temp reaches about 85 degrees, and Ford wants to hasten than point.
I can think of reasons to like this device and I can think of reasons not to. A tranny rebuilder on another FTE board claims this unit is notoriously unreliable and when it fails, it more or less permanently bypasses the coolers and leaves the trans vulnerable to overheating. I can see how that could happen.
Thing is, thus far, I'm not hearing much from other sources to back up his statements. Not calling him a "laar" because his particular experience could lead him to that conclusion. I'm looking for broader evidence, so if anyone out there has a story on this device to relate, or knows someone who does, would love to hear. In the meantime, I am contacting other sources to work up my data.
Old 03-04-2009, 08:34 AM
DarrinBC's Avatar
DarrinBC DarrinBC is offline
DarrinBC is starting off with a positive reputation.
This 'tranny rebuilder' wouldn't happen to be dirtydog would it?
For the record, I haven't seen problems with the thermal bypasses.
Any chance you can pm or email me a link? I want to read this one myself.
Darrin
Use the trans cooler in radiator or not? mototrig 1999 - 2003 7.3L Power Stroke Diesel 15 01-17-2014 07:20 PM
Anybody ever bypass the coolant valve on the intake? wastingas 1997-2006 Expedition & Navigator 0 08-23-2013 02:44 AM
Write Up: Bullet-Proofing the 6.0L PSD. colo_dually 6.0L Power Stroke Diesel 22 06-18-2011 11:10 PM
Transmission Cooler Bypass E4OD linckeil 1987 - 1996 F150 & Larger F-Series Trucks 2 09-13-2009 12:02 AM
98 trans. cooler bypass valve is singing on E40D rangedog 1997-2006 Expedition & Navigator 2 03-25-2004 10:58 PM
Tags
bypass, f150, ford, location, thermal, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
