Coolant Leak/ Head Gasket? '95 Bronco 5.8 - Ford Truck Enthusiasts Forums
Old 03-04-2009, 01:19 AM
dwg999 dwg999 is offline
dwg999 is starting off with a positive reputation.
Unhappy Coolant Leak/ Head Gasket? '95 Bronco 5.8
Guys,
I just want to get some confirmation before I dive off and replace my head gaskets.
I noticed a coolant leak from the back side of the motor behind the intake. I can't get a real good look at exactly where the coolant is coming from but it appears to be streaming down the backside of the heads. It is clearly not coming from the heater core so my conjecture is that it is either a head gasket or freeze plug.
There is no water in the oil and I can't detect in oil in the coolant.
Is there a sensor or some other plumbing on the backside of the motor that I am unaware of?
The motor has about 150K on it so should I bother replacing the head gaskets or just get the motor rebuilt?
Old 03-04-2009, 03:04 PM
poffutt poffutt is offline
poffutt is starting off with a positive reputation.
It makes me feel bad when someone gets no response for help with something that is really important. I guess you need to upgrade something to get any help.
First, I would not pull the heads and think the worst. Check your water pump and hoses. I know they are not in the back, but so many times people just want to assume the worst. Even a leaky water pump can have water blown onto the heads and run all the way back and leak. Some times you cant find the trail of water because the heads get so hot it evaporats before you can see it. Look for discoloration of trails from your pump to the place where you see the water. Follow it backwards and forwards to the front and rear. Look for any suspicouse marks, trails or discoloration. Good luck and let us know what you find.
Old 03-04-2009, 04:27 PM
thanks
Thanks for the reply.
One of the main reasons I initiated the thread is for the same reason you bring up. I know I am assuming the worst and was just searching for any other explanation other than what I know it is.
Your advice regarding the water pump is a good one and I'll give the motor a thorough going over before I make the determination to pull the heads.
It seems to leak even before the motor gets very hot so if water is coming from somewhere else and draining back to the rear of the motor then it should be visible.
Thanks again.
Old 03-04-2009, 05:06 PM
maneyup maneyup is offline
maneyup is starting off with a positive reputation.
i was kind of hoping someone would post right away with great insite but it doesnt always happen that way. poffutt has a good point with the water pump. anouther thing to think of is the intake manifold. intake manifolds have cross over tubes that flow with coolant in the front and back of the intake. it is a less costly and much easier repair than removing heads. frost plugs dont usually spray up to the heads but i guess anything is possible. a good way i have checked these things is to get a good flash light and a mirror and reflect the light and image into the mirror and you should be able to get a decent look at the back of the heads and intake.
Old 03-04-2009, 05:48 PM
Mirror
A mirror was my next step.
I'll let you guys know what I find.
Thanks for the replies.
Old 03-04-2009, 05:58 PM
bigunred's Avatar
bigunred bigunred is offline
bigunred is gaining momentum as a positive member of FTE.
i had a similar problem on a truck i used to drive it had a 351w, the rear water passage on the passenger side of the intake gasket was leaking you might check that.
Old 03-06-2009, 12:49 AM
boosterp boosterp is offline
boosterp is starting off with a positive reputation.
Quote:
I thought the same.
Old 03-07-2009, 07:24 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
A dye to add to the coolant is available that will flourese (sp?) under a black or ultraviolent light. That might help you follow the trail.
Old 03-07-2009, 07:42 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Did you use a presure tester on it yet.??? Sometimes you just have to get on top of the motor to see ..The miror is a good idea...Lew
Old 03-08-2009, 11:48 AM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
I am currently going through a similar issue of what appeared to be water leaking from the head, but I found my leak between the timing cover and the block. Make sure you know where your leak is because it take some work to get that all apart.
Also, some of those bolts in the water pump can become frozen in the aluminum pieces to the point that you snap them off. Good luck!
Old 03-12-2009, 07:28 PM
Smile It Wasn't The Heads
Guys,
As it turns out, there is a heater inlet tube that mounts on a fitting that screws into the intake. This presses onto the fitting (I found out) and the seal consist of 3 o-rings (no threads or anything else). I realized when I took a closer look at the top of the intake that the water was indeed flowing from the front of the intake (right behind the thermostat housing) all the way out the back.
I am still not sure whether the leak was coming from the fitting screwing into the intake or the 3 o-rings on the inlet tube but when I dis-assembled the fitting applied teflon tape to the threads and replaced the o-rings it solved the problem.
Needless to say, I am quite pleased to have my Bronco back on the road.
Thanks for the advice everyone.
Coolant leak after oil/EGR cooler Sullid01 6.0L Power Stroke Diesel 11 12-23-2014 12:32 AM
Coolant leaking from oil pan after new head gaskets! Hotrodhoarder 1973 - 1979 F-100 & Larger F-Series Trucks 108 08-29-2014 06:25 PM
Plymouth Coolant Leak? chillman88 General Automotive Discussion 6 12-30-2013 09:39 PM
Blown gasket or cracked head? DPDISXR4Ti Ford Inline Six, 200, 250, 4.9L / 300 31 06-19-2012 08:41 AM
6.0 bad heads diputseno 6.0L Power Stroke Diesel 33 05-01-2011 09:50 PM
Tags
1994, 1996, 58, bronco, coolant, detect, ford, freeze, gasket, intake, leak, location, lower, plug, small, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
