P1248 Turbocharger Boost Pressure Not Detected
After doing diagnostics with my AE It came up with these DTC any one know what there mean <title>-II DTC Report</title>
B1203 Fuel Sender Circuit Short To Battery
<title>AutoEnginuity OBD-II DTC Report</title><title>AutoEnginuity OBD-II DTC Report</title><table align="center" border="0" bordercolor="#bebbbb" cellpadding="2" cellspacing="0" width="750"> <tbody> <tr> <td align="left" width="750">C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open(I dont have air susp)
</td></tr></tbody></table> <table align="center" border="0" bordercolor="#bebbbb" cellpadding="2" cellspacing="0" width="750"> <tbody> <tr> <td align="left" width="750">P0657 Actuator Supply Voltage A Circuit Open </td></tr></tbody></table>
batteries are good and i drive the truck every day I have cleared the codes a couple times and got back the C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open wich is strange considering i dont have air suspension.
The other DTC are new other than my codes for my parkaid wich doesn't work. I also get a B1483 brake pedal input circuit failure - B1203 Fuel Sender Circuit Short To Battery .
and I got a DTC P0457 Evaporative Emission Control System Pressure Sensor Leak Detected (Fuel Cap Loose/Off) after clearing the other codes
ya it set for the 7.3 enhanced powertrain i have the 7.0 vers i tried to do the 7.01 update but everytime it was just finishing downloading the DTC s i would get a windows message saying progranm has stopped working then it closes AE so i uninstalled it and reinstaled the vers 7.0 from my CD.
WoomaHodal
72
02-20-2013 05:49 PM
