Magnesol question. - Ford Truck Enthusiasts Forums
Magnesol question.
Old 03-03-2009, 07:56 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Magnesol question.
Anyone wish to share their dry wash designs / ideas?
We currently pump our bio into a 60 gallon cone bottom tank that we use for water washing. If magnesol is added to the bio and mechanically stirred, will it be able to come out the 3/4 inch outlet, or will it need to go into another tank before it gels?
thanks
Old 03-03-2009, 08:21 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Sure Most people put it into a open tank, and let it settle, then decant the clean bio off the top, and then scoop out the "mud" from the tank when it builds up.
I use a different system ( go figure!). I use a diaphragm pump, and force it through 3 filters. I start with a 50 micron, then a 25 micron, then a 5 micron. For a final filter I use a 1 micron absolute.
Old 03-04-2009, 02:02 PM
Rushmore X's Avatar
Wonder how far up I would need to put a standpipe in the barrel to drain of as much as I can before decanting?
Old 03-04-2009, 03:50 PM
Trial and error?
Old 03-04-2009, 04:11 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Hey Fab what happened to the hydroclone to seperate Magnesol?
Quote:
I dont know if a standpipe is a good idea because the current generated as the BD is drawn off may stir up the magnesol.
In this case I would attemp to remove BD from the surface, possibly with a pump.
Old 03-04-2009, 04:37 PM
It was problematic.........Required constant adjustment. I now "power filter" it through canister/bag filters with an air powered diaphragm pump.
Old 03-04-2009, 05:08 PM
Phydeaux88's Avatar
Quote:
Sounds like a work in progress.
Old 03-04-2009, 06:44 PM
Everything I do is a work in progress! I'm never satisfied, always trying to make it better...............
Old 03-05-2009, 02:08 PM
Rushmore X's Avatar
Googled Magnesol since nothing on EBAY except filters. looks like fryer... and Dallas group are the only sources? Cheapest I found was ~89 bucks for 45 lbs + shipping. Is this the best deal?
Old 03-05-2009, 03:06 PM
I can get it to you for half that price...............As long as you buy 40,000 lbs.
Old 03-05-2009, 04:25 PM
Rushmore X's Avatar
40,000 lbs... that should make a few gallons...
Old 03-06-2009, 04:29 PM
TchTchr TchTchr is offline
TchTchr is starting off with a positive reputation.
Isn't the same stuff that restaurants use to pollish their oil? If so, would a foods supplier have it? We use it at church during our fish frys.
Old 03-06-2009, 05:26 PM
Quote:
Same company (Dallas Group) Different product. Magnesol was made just for Biodiesel.
Old 03-06-2009, 10:16 PM
Is it similiar in properties? I know the oil I get from the fish frys is incredibly clean. Also, right before our school took out its deep fryers they used the product and it transformed previously unusable oil to VERY clean oil. Just wondering.
Old 03-06-2009, 11:28 PM
Rushmore X's Avatar
what is the ratio that is needed per gallon of bio that has had the methanol distilled out of it? Saw 8 oz. packages for under 2 bucks and thought that I would get just enough to treat a batch to show my partner and try and talk him into dry-washing.
Tags
magnesol, oil, restaurant, safety
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
