I'm just getting around to changing oil and filter in my 85 6.9 that I bought. Question is, how much oil does it take with an oil and filter change? Also what weight of oil is suggested?
10 quarts stock, 11 quarts if you use a PSD oil filter. I would actually recommend that you install the PSD filter, as it both is larger and filters better.
i used the PSD filter once i liked it till i changed the oil next time. it was just long enough that it had to be tilted to get it off and out. so after that nice day of oil running down my armpit i figured iy wasn't worth it for me
If you look at the angle the filter header sets at, it don't make any difference if you use a long or short filter.
They both will be tilted just enough that oil will run over the side when you remove it.
The only way around that is drive a center punch in the bottom of the filter and let it drain before you remove the filter.
