Paint Color Code?
Paint Color Code?
I used to have a 1995 F-250 which I miss a lot, but being in college when gas went up a few years ago, I could no longer afford to put gasoline in it, as many of you with getting 10 mpg highway loaded or unloaded. So anyhow, I was wondering if anyone can tell me what Ford called the color, as when I graduate here in a year, I am going to find a nice 1996 F-250 or F-350, and have it painted to match my old truck. I have only ever seen 3 truck so far in my life this same color. As far as I can tell it was called Deep Forest Green Metallic. I can't get the paint code off of it, obviously, because I no longer have it. The color sort of changed from blue to green depending on the light it was in, as you can see from the picture.
Thanks.
Mike
Thanks.
Mike
Thanks.
Mike
Thanks.
Mike
Thats a great color. My previous truck was a 95 XL that was deep forest green metallic with the tobago (teal) lower accent.
FYI, If you repaint a truck and change the color, the door jambs, underhood, between bed and cab etc all need to be painted or it will never look right.
Maybe someone that as a truck this color can check their door sticker.
Deep tourmaline /forest green duplicolor match? which one?
duplicolor changed the name of the NA green tourmaline paint and code they used previously. what is the new / best color they sell called? for ford tourmaline green called. I would like to get what matches on the first try for once. I'm sure some one has the info. thx I'm looking for a spray can.
http://paintref.com/cgi-bin/paintdet...i?wtcode=M6572
I have three different touch up paints for the Tourmaline color (pics attached). The first is Duplicolor, the second is Plasti-kote, and the third is Scratch Fix. The "scratch fix" is a little hard to read...it says NG FM 356 Dark Tourmaline Med NA NB ND Ford.
If none of these are available, you could have the local auto paint store mix you a small quantity and apply it with a Preval sprayer. They are cheap and available at the local hardware store, although I've never used one.
BMXpert23
07-31-2018 06:00 AM
pogo619
11-04-2017 09:13 PM
AstroFab
18
04-18-2017 09:52 PM
52 USCG Panel
32
03-10-2017 08:03 AM
Doubleclutch
03-06-2016 04:12 PM
