Water pump squeal? - Ford Truck Enthusiasts Forums
Water pump squeal?
Old 03-03-2009, 10:23 AM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Water pump squeal?
The other day I noticed a squealing coming from under the hood I figured it was a belt loose. So I checked the belts and did tighten my alternator belt some but the squealing was still there. When I'm standing there listening it sounds like it may be coming from the water pump. Will a water pump going out make a squealing sound, kind of like a loose belt would sound? I wonder too because my temp gauge hasn't gotten over 180 degrees the last few times I've driven. I didn't know if maybe it was because it was around 50 degrees outside or something else?? Thanks for any insight on this.
Old 03-03-2009, 01:19 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
Yes, a water pump bearing starting to go out will make a high pitched belt noise. As for not getting over 180 that is not related to the outside temps. Here in MN, when it is -20 the engine will still get to operating temp.
Old 03-03-2009, 09:33 PM
jsutton's Avatar
I don't know about the operating temp yet, but I checked the weep hole and there was no water coming out. So I don't know if it's going out or not? I'm gonna take the power steering pump belt off to make sure that's not it.
Old 03-09-2009, 11:43 AM
jsutton's Avatar
I posted this in my other thread about my issue with my carb leaking. But it quit making noise on it's own???? I don't know what the deal is. I drove it over 100 miles over the weekend and no abnormal sounds at all and the temp gauge stayed right at 180. I guess I'll leave it alone until it starts it again.
I just wanted to follow up on my thread. I don't like to leave threads just hanging, so that anyone searching with a similar problem can see what my outcome was. I don't know how many time I've searched and found someone with the same problem I have but they never came back to say what exactly it was or what exactly fixed it.
Old 03-22-2009, 08:20 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
could be water pump, when it goes it will sieze up if it is the bearing. Also check your idler arm. I had one of those bearings sieze too.
Old 04-03-2009, 02:10 PM
Macamon's Avatar
Macamon Macamon is offline
Macamon is starting off with a positive reputation.
I have the same problem, have been posting in a different thread. I'm reletively sure that my water pump is shot, indicated by the florescent green fluid under the vehicle. I have a 2000 F250 7.3L Diesel. What is a good source for rebuilt? I need bang for the buck right now cause I'm not working.
Thanks
Old 04-03-2009, 02:19 PM
senix's Avatar
autozone is probably cheapest
Old 04-03-2009, 04:29 PM
jsutton's Avatar
I agree the one at Autozone with the 1 year warranty is only like $16 and the lifetime warranty one is only $27. I like the lifetime warranty! I recently got a brand new radiator to replace the one my dad bought in 99 and they didn't give me any issues at all!
Old 04-03-2009, 11:58 PM
Macamon's Avatar
Water Pump
The pump for my 7.3L is L58-554 and the price is like $99. For that I might as well support my local rebuilder because it's an order item and
AutoZone is going to tack on another few dollars for shipping.
Quote:
Old 04-15-2009, 09:54 AM
jsutton's Avatar
Well the squeal didn't come back but I noticed a wet spot the other day under the front of my truck right in the front center of the engine. I got under it and looked up from the spot and sure enough there was a little drip of antifreeze fixing to fall off the water pump. I stuck my hand behind the pulley on the water pump and it was confirmed, antifreeze coming out of the weep hole. It left a wet spot about five inches in diameter after sitting for 5 hours. I guess now I know what my next project will be.
Old 04-15-2009, 10:05 AM
senix's Avatar
Yeah, I'd get to it before the weather turns hot or you have to go very far from home. Pretty straight forward job on your truck. Steam clean the front of it before you start that may help if you have any grease built up.
Old 04-15-2009, 10:11 AM
jsutton's Avatar
Hopefully I can do it this weekend if it doesn't rain too much. I don't have hardly any grease or oil on the front of my engine I just rebuilt it 3 years ago. It probably doesn't have over 5,000 miles on it. I know I should have put on a new water pump when I redid the engine, but I went ahead and reused the one I had. Oh well it lasted a little while. This pic of the engine was just taken a couple of months ago, it's pretty clean in there.
Old 04-15-2009, 10:19 AM
senix's Avatar
Yeah that looks great. I wish I had an older eng. so easy to work on.
Loud squealing at startup the last few days DoofusOfTheDay 1987 - 1996 F150 & Larger F-Series Trucks 9 03-10-2014 03:21 PM
1997 Ford F150 4.2L...Unknown Squeal jjirvine 1997 - 2003 F150 11 06-30-2013 06:07 PM
Power Steering Squeal Alcaeus 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 07-27-2012 04:46 PM
damn squeal at startup f150v602 2004 - 2008 F150 9 04-18-2008 08:43 AM
smog pump or belt tensioner squeal AggiePSD 1987 - 1996 F150 & Larger F-Series Trucks 6 12-16-2002 01:12 AM
Tags
302, alternator, discovery, f150, ford, hole, pump, ranger, squeal, squealing, squel, squeling, truck, water, weep
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
