Rust Behind Cab Corners - Ford Truck Enthusiasts Forums
Old 07-08-2002, 05:02 AM
CollinsCD's Avatar
CollinsCD CollinsCD is offline
CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.
I am getting ready to redo my cab corners on my 79 F350 4x4 and notice that I have some serious rust to the area behind the cab corners. I don't know if this is part of the rocker panel or the inner cab area. Do they make repair panels for this area or am I in seriuos trouble? Thanks!
Craig
Old 07-08-2002, 05:29 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
Try lmc truck, they have quite a few patch panels for these. You can also have some made or make your own. I made a panel for the underside of the roof and it wasn't all that hard, just takes some time.
You might look into fiberglass mat mixed with Por15. I saw a demo of a battery tray that was full of holes and fixed with fiberglass mat that was coated with Por15. It looked great and added some real strength to it.
Old 07-08-2002, 10:18 PM
Carlene's Avatar
Carlene Carlene is offline
Admom
Carlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputationCarlene has a superb reputation
Karljay - I used the fiberglass mat on the bottoms of our doors and although it gave it the strength, what a mess. The bodywork involved to make it look good was worse than grinding it off and welding patch panels in. The fibers show way too much for exterior repairs.
We used it on the floor boards and couldn't be happier. Definately added much needed strength. Main difference is we are planning on covering the floor with carpet so the fibers showing through once repair is complete doesn't matter. I imagine it would work just as well used on the interior of the cab corners since the exterior would need to be bondo'd anyway.
Like you, we saw the demo, and it made too much sense on how it works. It actually does work, but I don't recommend it in places you plan on having visable.
Carlene
Old 07-10-2002, 11:04 PM
Paso1 Paso1 is offline
Paso1 is starting off with a positive reputation.
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=6340&.jpg I just replace the cab corners on the 84 I think Ford filled the area with structral adhesive. Mine underneath were not that bad but fiberglasss matting would surely work.
Old 07-22-2002, 06:23 PM
stryder's Avatar
stryder stryder is offline
stryder has a good reputation on FTE.stryder has a good reputation on FTE.stryder has a good reputation on FTE.
Not to mention LMC body panels are not guarenteed from any shipping damage. Read the little disclaimer at the top corner of their catalogs. In fact, they say to EXPECT slight damage.
Stryder
:-X11
Old 07-23-2002, 11:27 AM
Drawsoncad420's Avatar
Drawsoncad420 Drawsoncad420 is offline
Drawsoncad420 is starting off with a positive reputation.
Cab Corner Replacement Question Chevmn56 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-17-2015 05:56 PM
rear cab lower patch panel ? do they make 1 bignuk1 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-10-2015 08:43 AM
patch panel rust prefention supercabfreak 1973 - 1979 F-100 & Larger F-Series Trucks 16 08-10-2010 08:43 PM
Rust Repair Panels from BOTP johaner78 Paint & Bodywork 3 03-23-2007 08:18 AM
Best patch panel source? Fat Fendered Ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-22-2002 01:02 PM
Tags
1938, 1979, 2004, 79, apply, cab, corner, corners, f150, f250, fiberglass, ford, panel, repair, rust
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
