Slice in Tire Tread
Slice in Tire Tread
I just got out my all season rims and tires and went to put them on when i noticed that one had a slice in the center tread line, they are general ameritracs, the slice is angled and cuts down through the thickness of the tread, the entire width of the tread lug, and just barely into the base of the tire (it might not even be into the base, but its dang close), i bought these tires used last year and they have alot of tread on them so i dont want to have to buy a new one. What can i do to fix it or is it ok. i just dont want a blow out.
I usually dont worry about slices in the tread, but this is the first one i have had that went as deep at the thickness of the tread and slightly into the base. Do they make a sealant or somthing i can use to seal it up?
Here are two pictures of the slice, i ran a bright green line next to the slice, i pried up on the top flap of the slice to look down in, but its hard to pry it up real far, i could see something down at the bottom of the slice, i dont know if it is just a spec of the cord showing or a small peice of sand/dirt.
I personally put alot of value in having excellent tires, so I would search craigslist for a matching replacement. Go back some years ago and there was a huge recall problem with tread separations on ford vehicles where the drivers lost control and were injured or killed. The pics show a tire which could easily get worse to the point of failure rather quickly. A tow would cost as much as a tire.
I was trying to say it would be a good starting point for a tread separation to happen there, and I personally would want piece of mind erroring on the safe side. Possibly nothing will ever happen, but since tires are rather inexpensive , I would swap it out anyways. Or , how about swapping it and that be your spare strapped under the truck?
If it were my tire, I'd replace it. It could be a place for tread separation to start. I don't mess around on tires, steering and suspension components, and brakes. Those are safety items that I won't cut corners on. Tire Rack and Discount Tire probably have them at a reasonable cost.
Greg B
Greg B
Well my local tire shop has another used one with the same tread left on it so it will match the rest of them. I checked over all the other ones and the rest of them are fine. I will change it out. I actually put my ATs back on last night cause im going on a short trip this weekend and would rather not deal with a flat!
madpogue
06-28-2014 10:44 PM
Truck610
07-10-2013 09:13 PM
