Starting truck without waiting
so i always wait 15-20 seconds before starting my truck. one morning i got in and without thinking turned the key and the truck fired right up. since then iv been starting it that way and was wondering if thats harmful at all to anything? the coldest that iv started it at without leaving the glow plugs on was 27 degrees.
You aren't doing any damage as long as she fires up right away. If you have to crank a cold engine, you are injecting fuel that isn't burning and is washing the oil off the cylinders as it runs past the rings into the oil pan. With a cold engine and air temp at 27*, I would use the glow plugs. Others will give their opinions.
Oh, yeah. Welcome to FTE!
i have a 2000 250 110,000 only pluged it in twice when it got below freezing and i had not run it for a few days. it was starting alittle hard early this winter so i replaced the glow plug relay and starts fine now. when its real cold and i have to use the truck ill cycle the glow plugs a few times.
BBslider001
45
10-18-2013 06:40 AM
BBslider001
20
09-01-2013 12:38 AM
brendo613
12-28-2011 04:25 PM
