Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-02-2009, 07:39 PM
Tom D Tom D is offline
Garage is empty, add now
Tom D is starting off with a positive reputation.
I'm doing something wrong
As of today, I have processed 465 gallons of bio. I HAVE NOT collected any methanol during any of the batches. I have talked to Fabman till (I think) he is ready to change his phone number. The only thing I can think that I am doing wrong is possibly heating the oil too high (150F-160F) to mix the Meoh with. I believe boiling point of methanol is approx 148F. Could it be I'm boiling off all the methanol while I am mixing it? I tried heating it in a pan and there appeared to be none in the mix after running it through the heating chamber (160F) I also tried to ignite a small quantity in a cooking pan with a torch. It did not readily burn. I have therefore determined there is no methanol in the bio so I dry wash with Magnesol. Where do you suppose the methanol went? I am thinking if I pull a vacuum on the line leaving the condensor, I could possibly lower the pressure and capture the methanol although I am not sure there is any to capture. Other than that problem, the bio is coming out beautiful and I am running B100 year round. I just would like to lower my costs by capturing the methanol. Any suggestions from you-all would be greatly appreciated. Don, you know exactly what my setup looks like so maybe you could jump in there again. Thankyou for all your help. Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #2 (permalink)
Old 03-02-2009, 09:15 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
We wait until the oil cools to about 135 before adding the methanol. The exothermic reaction maintains the temp during the reaction, and when all is done, both the glycerine and the bio have a rather strong methanol odor. Still need to recover the methanol from the glycerine, will do that the next couple days as we run the next batch.
You've got use beat for gallons processed, we've got some catching up to do...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 03-03-2009, 08:20 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
At 150F there is no doubt your MeOH went up the vent.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #4 (permalink)
Old 03-03-2009, 09:53 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Yep, toooo hot! Methanol boils off at 148.5 deg at sea level. I run mine about 145 deg, but my methoxide is premixed and cold when introduced.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #5 (permalink)
Old 03-03-2009, 06:40 PM
Thank you all for the info. I will make necessary corrections and try again. Tom
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
