97 F-150 4.6 missing - Ford Truck Enthusiasts Forums
Old 03-02-2009, 07:02 PM
volfreak volfreak is offline
volfreak is starting off with a positive reputation.
I have a 97 4.6 4x4 with 155k miles that started missing and check engine light came. I had the code read at advanced auto and it was cylinder 4 misfire. The plugs and wires were changed by dealer at 142k so I took a chance and replaced the coil packs and reset the computer. I still have a miss and now don't have a check engine light on. Why would the check engine light not come back on if it's still missing? Should I let the dealer change #4 plug and wire or wait for the check engine light to come back on?
Old 03-02-2009, 07:40 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
First off,I would not let the dealer do anything just yet....With that being said,I personally would wait until the CEL (check engine light) came back on,and read the code.You might also want to consider purchasing an OBDII reader,and keep it handy. These will work on almost all makes/models,and are pretty much a "must" for todays newer vehicles..............................Now back to the issue...Since the plugs,and wires have been changed recently,I have doubts that its either causing the issue.There is of course the possibility that either the plug on #4 is bad,or the wire.Wires can be damaged during installation,or removal.Plugs can get a bit of "garbage" on them,and misfire.....anythings possible.
Old 03-02-2009, 08:52 PM
Thanks for the reply.If the plug wire and coil pack are good what else could cause a #4 misfire.
Old 03-03-2009, 08:38 PM
Hillbilly_Deluxe's Avatar
Hillbilly_Deluxe Hillbilly_Deluxe is offline
Hillbilly_Deluxe is starting off with a positive reputation.
Whenever my truck has a miss, its because the sparkplug hole gets full of water. Just take the wires off and blow out the holes and It works fine again.
Old 03-04-2009, 07:22 AM
Quote:
Thanks for the reply. I'll try that this afternoon.
Old 03-04-2009, 07:25 AM
shawn_N's Avatar
shawn_N shawn_N is offline
shawn_N is new and has a neutral reputation at this point.
i would venture to say that you problem lies in either the plug or wire.
Old 03-04-2009, 09:06 AM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
Number 4 is the hardest to work on for that year. Plus it sits right below the heater hose and also water from the cowl area can leak right down into #4 hole. I would pull the wire and blow the hole out (as has been mentioned), make sure the plug is tight, put some dielectric grease down inside the boot, and snap it back on. If it still misses and you still get a CEL, misfire #4, I would pull the plug and check to see if the porcelein cracked, which would allow it to arc out. This plug is kind of hard to access and they may have cracked it putting it in. If all this checks out, make sure the connector on the fuel injector is snapped on tight. Many times these are taken off when they do plugs. One of mine came off shortly after I changed plugs, and I have to assume I didn't snap it on tight.
The advice on buying a OBD 11 scanner is a must these days. Mine cost $90.00 bucks, really is slick. Will pinpoint a miss right away. But... if the miss is light enough it will not trip a CEL. Computers have a threshold for a problem that delays tossing a CEL until "it" is convinced there is a true problem. Let us know what you find.
Jeff
Old 03-04-2009, 06:20 PM
I carried it to the dealer today and water had dripped from the heater hose causing #4 plug to foul. Thanks for all the replies and help.
Old 03-04-2009, 06:26 PM
Glad you got it fixed!'
Jeff
water in spark plug recess cardone 1997 - 2003 F150 24 11-09-2015 09:39 AM
Bad miss need help Cory West 1997 - 2003 F150 10 09-24-2015 08:50 PM
03 F150 Misfire Cylinder 6 sompin2do 1997 - 2003 F150 5 10-06-2011 08:15 AM
cylinder 2 misfire 97 expedition 4.6L tkobe Expedition & Navigator 4 02-01-2011 09:13 PM
check engine light still on after spark plug change LloydR 1997 - 2003 F150 4 03-09-2006 07:36 AM
Tags
1998, 46, 97, engine, f150, ford, foul, issue, missing, plug, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
