Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-02-2009, 01:32 PM
whiteaddiction whiteaddiction is offline
Garage is empty, add now
whiteaddiction is starting off with a positive reputation.
Do you guys use both heating eliments?
I have my first processor in construction, I figure if I only do a batch of about 20 gallons, The top heating eliment of my water heater will not be in the oil, So do I unplug the top one and just use the bottom? Also How hot do I set the temp on the water heater? 140 Degrees? And it will shut of when it reaches this temp?
  #2 (permalink)
Old 03-02-2009, 06:02 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Only used bottom element (220). Heats up plenty fast. Also modified the heater to go up to 170+ by removing the stop on the thermostat. We took the top element out and put a plug in there so now there is a spare if needed...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 03-02-2009, 08:05 PM
Quote:
Will the heater shut off when the oil reaches temp? I thought 140 Was the tempature you where suppose to use?
  #4 (permalink)
Old 03-02-2009, 09:08 PM
Rushmore X's Avatar
2003 Ford Excursion
Yes, the thermostat limits the temp. Sorry for the confusion, we run ours hotter for de-watering and distillation of the methanol. We run the reaction @ 135.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
