oh dear !!
oh dear !!
just came back off holiday for a month and the f350 started first turn!..went to work in it today no problems !distance about 25 miles !!... On the way haome i noticed that the ( oil pressure guage ? ) went way down past the " L " reading when i backed off the " go pedal " to slow down... it returned to just past the " L " reading when i accelerated again although ( even on the freeway ) it never reached the middle of the " normal " reading " !!... then just as my house was in sight it engine completly stopped !!!!... after waiting for about 2 mins i managed to re-start the engine !... and parked it up on the drive!... any ideas what might be wrong?????
1989 van.. the engine ( apparently ) is later .. possibly a 94 !... non turbo... and no ! i haven't checked the dipstick yet !..there was plenty in it last year !! parked on a steep gradient !!..useing mum's honda tommorrow will check the oil after work !!...........
First off, is your vehicle an F350 truck or an E350 van? If truck then read below:
Your '89 gauge ain't no real gauge unless you've performed circuit board surgery behind the dash, and your '94 sender ain't no real sender either, but just a pressure switch - when oil pressure is above certain number (7psi IIRC) all reads good, when under that number gauge drops to zero and your engine light should come on. Any fluctuations in the gauge readings you see while driving are due to heat soaking of the sender, and are in no way related to actual oil pressure fluctuations.
Now, the idiot setup of the oil pressure gauge I just described came about for '87 pickup trucks, it was brought in along with the new dashboard. I'm not sure when vans got updated interiors, or if they ever did between the early-'80s models and before the '92 redesign, so your gauge may actually be a real gauge, and your sender may actually be a real sender.
And no, no oil pressure shutoff switch on any of these trucks.
However drive it some more to see if it is an engine fault or the trans.
i have just checked the oil !!... there was nothing registering!!.. just put in about 1/2 gallon.. all i could find of (15-40) !..... it still does not register anything on the dipstick !... started her up.... she's a lot quieter now... also the " oil pressure ? " indicator is now very almost in the middle of the " normal " reading ????... when i took her off the drive ( to put her on a more level hard standing) she accelerated on her own as soon as i put her in gear!... this did not happen when i put her back on the drive again !????........gonna get some more oil tommorrow ( still using mum's Honda!.. but she wan'ts it back on friday )..!!.........................
ok.. will do.. and thanks !!... oh just remembered.....she was down to just under 1/4 fuel on the front tank when she shut down... i switced to the back tank which is over 3/4 full... when i used veggie oil in her and switched over she some times used to rev up then!!???... is it possible that there is still some residue in the fuel filter???... and this is what is causing the phantom acceleration??
