Ranger Engines with Timing Belt? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-02-2009, 10:47 AM
therealulysses's Avatar
therealulysses therealulysses is offline
therealulysses is starting off with a positive reputation.
Hi. I'm looking for a used Ranger from '96 to about '03. Which engines have timing belts and which have timing chains? It looks like the 2.3 and 2.4 have belts. What about the little 3.0 V6? I'm pretty sure the 4.0 V6 has a chain.
I thought they all had either chains or gears. Now I'm not sure what I was reading.
One interesting thing I found was a chart showing gas mileage--it has been getting steadily worse over the years. Maybe I should be looking for the oldest Ranger. What was the first year? California makes you get a smog test for anything '77 or newer.
Old 03-02-2009, 12:20 PM
BSmitty's Avatar
BSmitty BSmitty is offline
BSmitty is starting off with a positive reputation.
2.3l and 2.5l (thru '01) have belts, also the older 2.0l. The 3.0l has a chain, it's short because it's a pushrod engine. I'm not even sure about the Duratec ('01 and up 2.3l), but it seems like they have a belt as well. BTW, the first year of the small ranger was '83.
Old 03-02-2009, 03:04 PM
2.5 and not 2.4 eh? It looks like I got some misinformation from reading old posts. Plus I get mixed up because I have a Mighty Max with a 2.6L which is actually a 2.55L and I have a Nissan with a 2.X 4 cyl and I'm not even sure what they call it because so far I haven't had to do hardly anything to it (180K miles on it or thereabouts).
Old 03-02-2009, 04:19 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
The Duratech (16valve) 2.3 has a timing chain.
Old 03-02-2009, 06:53 PM
BSmitty's Avatar
Ah, good to know!
Old 03-02-2009, 07:07 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Everything on the 01+ 2.3 is chain driven. Cams and oil pump
Old 03-03-2009, 09:26 AM
I had looked up the engines and *thought* they were all chain-driven so it looks like that must just be for the newer ones. Any problems with the cam chains/tensioners like they had on the 4.0 SOHC several years ago?
I like the gas mileage of the 4 cylinder engine (if it's a regular cab and regular bed) and it's usually very easy to get to spark plugs and most components but I also have grown to prefer OHC engines on general principles for durability.
Any opinions on which is the better engine, the 3.0 OHV or the 2.3 which I take it is a OHC? Currently I have a Nissan Frontier (got crashed) with the little 4 cyl with about 180K on it and it has had no problems at all. I also have an '88 Mitsubishi Mighty Max with the 4.6 4 cyl with 240K on it. Both have timing chains. The Mighty Max was abandoned on top of a hill for several years with the hood open. The engine (and carb) was froze. I got it unfroze and it still runs pretty good.
Old 03-03-2009, 10:17 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
duratec has belt, but is belt brakes, you get broken valves... old 2.3 was non-contact engine, newer DOHC unfortunatly.... ouh, change belt every 60K and be sure all driven with belt components are ok every time you change a belt.
3.0 is much more reliable then four banger. The weak points are gaskets and heads. But heads fail in case of really serious overheating.
old lima 2.3 is reliable too, but if you haul a lot its torque is to low, especially with auto. So 4-cyl engine is good with manual tranny.
Old 03-03-2009, 11:51 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
The duratec 2.3 has a chain, it's been used in the ranger since 01. They have a 2.5 version of the duratec used in the escape this year and it also has a chain. The old lima 4 cylinder had the belt. The only problem with the tensioners were on the 4.0 sohc, nothing else.
Old 03-03-2009, 12:15 PM
i may be wrong. ford may call duratec different engines. they call duratec made in Cologne plant engines here. so I see 4 cyl engines by ford with chain and with belt.
Old 03-03-2009, 01:18 PM
Yeah, I wouldn't say your wrong, just mistaken. Our duratec since it's introduction into the ranger in 01 is chain driven. Before that it was a belt in what we call the lima the 4 cylinder because of it's city of origin, lima ohio. The lima was used in ford products from the early 70's untill 01.
Old 03-03-2009, 01:30 PM
Thanks guys for all the helpful info. I'm looking for a Ranger for my daughter and I don't expect her to be hauling much or towing anything so it sounds like '01 or newer for a 4 cyl or just get the 3.0. There seems to be moslty 3.0s available anyway.
I have a tendency to keep my Ford trucks so I'd rather get one that'll probably last longer. Timing belts sound like a PITA. At least head gaskets don't usually need to be replaced every 60K.
Old 03-03-2009, 01:33 PM
lima 2.3 and eu 2.3 are a bit different. Lima had made of cust iron head, EU 2.3 - made of aluminium head.
It is like when ford started GAZ in Russia, GAZ redesigned US engine and made it of aluminium.
My fried swaped engine in his '86 aero. Had 2.3 lima, now he has 2.5L4 Cologne. Both are with belt driven cam.
well, about duratec: Ford Duratec engine - Wikipedia, the free encyclopedia
Old 03-03-2009, 01:42 PM
I'd prefere old good 3.0
Old 03-03-2009, 02:21 PM
Thanks for the link but now I'm confused. Is the 3.0 V6 also called a Duratec? It looks like there is also a 2.5 V6 but I'm not sure if they put them in Rangers or not. So now if I see an ad that says "V6" I'm not sure which engine it has.
Timing Chain brent1204 Ranger & B-Series 3 07-06-2015 08:18 PM
what year was Duratech 2.3 don77 4 Cylinder Engines 5 11-26-2011 08:18 AM
3.0 & 4.0 life expectancy & timing chain reliability TheHandyman Aerostar 14 09-13-2007 05:10 AM
Chaining timing chain on 1990 ford ranger 2.3L fattyarbuckle Ranger & B-Series 2 06-09-2003 11:02 AM
Timing chain (belt)? StangVT66 Ranger & B-Series 2 01-21-2003 12:19 PM
Tags
1999, 2009, 23, 40, 96, belt, chain, dohc, engine, ford, pushrod, ranger, time, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
