460 horsepower/torque specs?
I Know this ahs been asked before, but what should I expect out of my stock '85 460 with emission heads and chain set? It has a 600 vac. 2nd holley and factory intake and exhaust manifolds. I will be running dual 2 1/2 with flowmasters and side exit behind the tires. Also what will I gain by putting that older (pre-emissions) chain set in it? how far back do I have to go to get the older set?
Maybe you can get moved to the 385 forums.
460s of that era were about 230hp, 390tq. + your mods, - age and wear, you are somewhere near that. Change the timing set, maybe 15 or 20 hp...WAG.
Pre-71 methinks for the timing set, but you can search the 385 threads or, if you post gets moved there, get an answer. Monsterbaby is an excellent resource for these engines.
Nothing Special
36
11-23-2021 11:34 AM
oldmerc
08-18-2015 08:24 PM
Crewcabber
05-30-2015 05:53 PM
John with beastly 302
27
11-14-2008 11:09 AM
fordxxx
01-21-2003 12:31 AM
