460 horsepower/torque specs? - Ford Truck Enthusiasts Forums
Old 03-02-2009, 01:36 AM
hillbillydaddy87 hillbillydaddy87 is offline
hillbillydaddy87 is starting off with a positive reputation.
I Know this ahs been asked before, but what should I expect out of my stock '85 460 with emission heads and chain set? It has a 600 vac. 2nd holley and factory intake and exhaust manifolds. I will be running dual 2 1/2 with flowmasters and side exit behind the tires. Also what will I gain by putting that older (pre-emissions) chain set in it? how far back do I have to go to get the older set?
Old 03-03-2009, 02:45 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Maybe you can get moved to the 385 forums.
460s of that era were about 230hp, 390tq. + your mods, - age and wear, you are somewhere near that. Change the timing set, maybe 15 or 20 hp...WAG.
Pre-71 methinks for the timing set, but you can search the 385 threads or, if you post gets moved there, get an answer. Monsterbaby is an excellent resource for these engines.
TAILGATE CHAIN COVERS ? oldmerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 08-18-2015 09:24 PM
1977 460 retarded timing set and factory emissions Crewcabber Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 05-30-2015 06:53 PM
timing chain with multiple adv/rtd postions Ds7776 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 06-30-2011 10:16 PM
Want to upgrade my 79 F250 460 79f250460 1973 - 1979 F-100 & Larger F-Series Trucks 42 12-17-2008 06:46 PM
460 Timing Gear SuperSnake Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 11-15-2007 09:13 AM
Tags
1972, 460, 71, bbf, ci, exhaust, ford, horsepower, hp, hptq, manifold, motor, specs, stock, torque, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
