PCM Failure
PCM Failure
So like most tuned 7.3 I was reflashing the pcm in a parking lot and the pcm fuse gave up the ghost! The pcm decided to go the way of the dodo and is now a wheel choch. Has anyone managed to get the 275 hp manual trans software in a pcm with an auto trans. Or is there a resonable price performance pcm tht is stackable with a flash tuner.
I'll bet F-1 actually has a manual and just said PCM instead of ECM!
The only things that can be stacked are things like ICP foolers. But that's old school technology, since any chip or programmer can now control ICP through tuning. So now even that kind of stacking doesn't work anymore if you are tuned correctly.
Tell me if you have an HEP or CKM prefix serial number. I've uped CKM which has an external (In PSD slang) IPR and the HEP is the newer pump style with an internal IPR. Trust me I cant remember all my year date and model breaks. If your thinking of the injectors responding to pre split shot programming. Yes it works. on Cat. Get me the serial and I'll pull the cat dyno sheet and tell you just about anything you want to know.
Kal serials have been our latest fun. There is no calibration or infered values that can moniter exhaust flow so a straight pipe is possible at your discretion. The biggest things I stress to my customers with that serial range is to maintain oil change intervals shorter than 7000 miles and keep an eye on fuel pressure. There is a checkvalve regulator at the rear of the cylinderhead that is often prone to failure. remove it with a 7/8 wrench and if the center portion is protruding at all its bad. It should be recesed.. The part number is 294-8620 and the seal ring is either 214-7568 or 214-7567 cant remember them all. The serial you have should have a fuel pressure sensor but some mfg have opted not. The ecm uses software that not only has split shot but works up to five shots and the injectors actualy are physicaly diff than pre 03. Cats biggest fault with the engine was the ecm calibrations had limited injector compensation for wear this combined with fuel pressure issues and lack of f/p sensor and fuel map derate lead to seveare injector performance complaints. Ill ohm out some injector selonoids that I have and see if they compare. If they ohm the same and the ecm pin location works the HEP serial 3126E share the same pump style. HEP s do have split shot but only one.
I did revive my PCM i booted it as a blank and even salvaged my programmer. Any one have simple ideas on single shot software. Cant use ford that I have access to because the software works in packages, flash for a 97 and get trans and 4x4 functions for a 97 and not be able to work with my factory GEM module.
Kemmpe ? Only one repair on warranty. 860ft/lb on the dyno no need for your 30hp you feel you have a power issue? The engine dynoed with 80psi fue press make sure you have atleast 75 psi full rpm no load an no less than 68psi pulling. Also be carefull if anyone has ever replace injectors you can put the wrong ones in and the parts look up for these engines and cat is very missguided.
