Yes, thank you, I know I was close, what did you do that i was doing wrong???
Thanks again.
Sorry for not getting back to you sooner. I didn't see your response in the sea of X pics. But, in case nobody else answered yet, I think you just put in the wrong code.
on your webshots account, if you click on an image, in the bottom right hand corner, right below the photo are a bunch buttons. One of them is the 'copy code' button. After you click on that, pick the size you want (probably 600 pixels) and copy the "direct link to image" address. Then paste like this: (img)PASTE_HERE(/img) but you have to use brackets [ ] instead of parentheses ( )
Hollister, Ca and we go any where from 100 to 125 psi depending on the load we have
How long is that toybox? Have you ever weighed the tongue? What's it weigh empty and ? gvwr. Sorry for all the questions. How about some pics of the hitch setup your are using. Does it give you a white knuckle pull?
I have a 34 ft Vortex bp th 8600# empty with a 13,500 gross. I don't like the way it pulls behind x. I prefer a dually but wife wanted the x.
