94 ranger weird noise
Old 03-02-2009, 04:34 PM
slomafarms's Avatar
slomafarms
slomafarms is offline
i just test drove a 94 scab v6 auto trans ranger today and i was wondering about a weird noise coming from the rear of the truck...dont know if its the trans or rearend...its a clicking noise, clicks faster the faster you go...its not loud but noticeable
Old 03-02-2009, 06:08 PM
michigan66's Avatar
michigan66
michigan66 is offline
Did you look at the driveshaft, especially the U joints, to see if something is wrapped around it and is hitting the body as the shaft or joint turns. I could be something loose in one of the brake drums that is rattling. Does the sound seem louder on one side of the truck that the other side? It could be a nail or bolt stuck in a tire, as well. Jack up the rear end, start it up and put it in gear. Walk around the truck and see if you can locate the sound. If it seems to be around a wheel, shut everything down. Turn each wheel by hand. Does anything rattle or squeak? If you have hub caps, pull them off to see if lug nuts are loose/ if the wheel is loose. Feel around the tread and edges of the tires to see if something is sticking out of them. Let us know what you find.
Old 03-02-2009, 07:04 PM
slomafarms's Avatar
slomafarms
when i drove it, it seemed to have good brakes...for the miles that it had it ran great! if i buy it ill look into it and let you guys know what it is....thanks fot the things to look for
fordfan302
06-09-2013 03:42 PM
93f1505.0L
01-20-2006 08:47 PM
Big 89 Bronco
1978 - 1996 Big Bronco
12-16-2002 07:03 AM
RBrendel
16
05-11-2002 09:25 PM
Quick Reply: 94 ranger weird noise
