Towing with no tow package
Hi All,
I have found a 2006 F150 SuperCrew 5.4 to replace my '97 Dodge. I pull about 5,000 lbs. of camper through the mountains frequently. But the truck is not equipped to tow.
I will would add Hitch (duh!), wiring harness, brake control and trans-cooler.
What else does this truck need?
Any reccomendations for towing with this truck?
Thanks!
Will
Thanks!
Will
IMHO 70 mph is way too fast for towing. I'm not sure what you ment by the axle ratio, 3.73 is better for towing, the LS is really not that important for towing on the road.
Others will chime in but 60mph is a lot safer and not as hard on equipment. You said Mountains, going up hill you will be lucky to hold 60 with out gas pedal to the floor and going downhill you would be better served to use the engine to brake. OD works for flat ground but if you are pushing a lot of air or have taller tires you will feel it.
you can tow around 7,000 lbs with these trucks...just dont go too fast or too hard...if you tow a heavy load alot i would say add a trans temp gauge so your trans doesnt end up being big a block of metal from pushing it hard too long...tow haul mode was put in 05 i think...i know my 05 f250 6.0 has it
Oh, that's good. So you are aware that ALL ST trailer tires are ONLY rated to 60 MPH, right? Exceeding a tire's rated specs is dangerous at best, and deadly at worst.
Secondly, all 5.4s come with the 9.75" rear, which should stand up to heavy towing just fine. The biggest weak link I see without the towing package is transmission cooling. The truck already has a 5-pass transmission cooler, whereas the trucks with the towing package have a 9-pass cooler. It's mounted behind the front bumper, and I'd recommend changing it out for a larger one.
As others have stated, you want to keep an eye on your trans temp, but you're not likely to have large problems with 5,000 lbs, as that's what your truck is rated to tow without the tow package. It'd be over 8,000 lbs with the tow package. Well worth putting the tranny cooler on, though.
Didn't mean to get you in trouble!
Seriously, though, I did some more digging, as I hate to mention something without being able to back it up. Apparently, I was wrong about the maximum speed, it's really 65. Oops!
And here are my sources....
Discount Tire
http://www.goodyear.com/rv/pdf/marat...nfo_032806.pdf
http://www.netmdc.com/~desertskies/Tires.pdf
BoatUS.com: Trailering Club
I never really thought much about tires until I started driving a commercial truck...
Discount Tire
