Wheel weight clean up?
Old 01-30-2011, 02:47 PM
Rugby3's Avatar
Rugby3
Rugby3 is offline
What is the best method for removing this kind of residue from wheel weights? I've tried a green scrubby but that doesn't do very much. Any thoughts from the pro's would be greatly appreciated.
Old 01-30-2011, 03:39 PM
Action4478's Avatar
Action4478
Action4478 is offline
Sand blaster & polish with a Carbo cut wheel , then re -clear it ...
Old 01-31-2011, 10:10 PM
Chaosracing's Avatar
Chaosracing
Chaosracing is offline
Its not residue from the wheel weights. Its oxidation on the aluminum. Only way to remove it is to sand the area, progressing to a real fine grit paper, then polish, then reclear. If possible, I try to either remove the wheel weights once in a while and apply a real good coat of wax then reattach the weight. Another way to avoid this would be to use internal ballancing or weights on the inside part of the wheel.
Old 02-01-2011, 06:14 PM
Rugby3's Avatar
Rugby3
Rugby3 is offline
Thanks for the replies.
jps47
11-10-2013 05:16 PM
henritrinelli
1978 - 1996 Big Bronco
26
07-24-2013 05:03 AM
Scott 73
Georgia Chapter
04-27-2011 06:41 PM
Bigfwt04
38
12-22-2008 12:47 PM
Quick Reply: Wheel weight clean up?
