Deferential
Old 10-08-2018, 09:52 PM
Mike Malone's Avatar
Mike Malone
Mike Malone is offline
Deferential
New spider gears and pin also new axel gears...still have up and down play in spider gears...is this normal...?
Old 10-08-2018, 11:31 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Not sure what you mean by up and down.
The side gears run in the side bearing centers and are splined to engage the axles.
The top and bottom spiders run on the big pin.
Where is the movement and how much?
If more than about .010 or so, some other part is worn or the side bearings are not taken up enough with shims.
Remember the S spring has to go in and put pressure on the spider side gears, especially to put pressure on the Traction Lok clutch disc stack if equipped.
The big pin cannot move with the lock bolt in place.
You ought to be able to tell where the excess clearance is from if it's that much.
When you turn the pinion to rotate the ring gear, what does the spiders do?
You can come and ask but we can't see it.
Old 10-09-2018, 12:03 AM
Mike Malone
It’s a non limited slip no s clip ...all new gears have around an 8th of a inch up and down movement when I push on the spider gears I’m wondering if this is normal also hear a slight clunk when shifting gears
Old 10-09-2018, 12:27 AM
Bluegrass 7
An eighth of an inch is .125" of an inch.
I would say no not normal..
No wonder you hear a clunk.
The most a ring and pinion should have is about .015" +/-.
Old 10-09-2018, 01:00 AM
Mike Malone
ok thank you
Old 10-09-2018, 03:48 PM
BigEd54's Avatar
BigEd54
BigEd54 is offline
Little bit confused. Are you talking play in the spider gears or in the ring and pinion gear?
bad12jr
17
04-08-2009 02:44 AM
Hiflyer746
03-26-2009 06:42 PM
Kerrie
1997-2006 Expedition & Navigator
02-04-2008 05:07 PM
alkitchen
06-03-2003 12:53 AM
brett_d
06-21-2002 07:18 PM
Quick Reply: Deferential
