Brake pedal goes to floor - Ford Truck Enthusiasts Forums
Old 03-01-2009, 10:32 AM
BNeu11383 BNeu11383 is offline
BNeu11383 is starting off with a positive reputation.
Cool Brake pedal goes to floor
You guys are my last hope so here goes. 1993 F150 4x4. The truck has a hard brake pedal till i start it up and then i goes straight to the floor. The Problem Started out as a hanging caliper. Replaced pads and away i went. Half way home my pedal went right to the floor. Bled the brakes and not any better. So bought a Master cylinder and bench bled it, put back in and no better. Said hell it started with a hanging up caliper so ill replace them and the hoses that go to them. Did that and rebled and still no better. Figured the master i got must have been bad so got another one. No better. Bought a booster and still no better. All the lines on the truck have been replaced but 2 and theres no leaking. I have bled the proportion valve and abs valve. I'm at a loss. Everyone i talk to has no answers.
Any Ideas would be great.
oh If i push the pedal to the floor while driving i can get the right rear to lock up but that is it.
Old 03-01-2009, 01:10 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
try sending a p.m. to "andym".
go to:
http://www.ford-trucks.com/forums/me....php?do=getall
then put in california for state and over to the right type in "andym"
in that list he is 3rd or 4th.
Old 03-01-2009, 01:39 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
oh If i push the pedal to the floor while driving i can get the right rear to lock up but that is it. :-hair
I would guess the first time it happened you had a master cylinder failure. I would further say that the problem now is the system is full of air. I would make sure the rear brakes are fully adjusted up and then bleed the brakes again.
Old 12-12-2011, 04:31 PM
workdad workdad is offline
workdad is starting off with a positive reputation.
I'll be watching
I'm having the same problem with my 95 250 PS. I haven't changed the booster or vacuum pump yet. I was going to change calipers, but maybe not now. Mine started with a stuck caliper as well. Got it unstuck and put new pads and it hasn't been the same since. Put in new master cylinder as well. Bled the thing at least 3 times. Same exact problem, but my pedal is a little soft with engine not running.
Old 12-12-2011, 04:53 PM
I guess I'll check on adjusting/replacing rear brakes. My Chilton Cd says there's a sensor, and the rear have to engage good before front will at all.
Old 12-12-2011, 05:06 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Don't forget to bleed the RABS valve on the frame under the drivers feet.. Since you replaced the master cylinder there is a good chance it has air in it..
08 F150 Brake Nightmare RED DYE 2004 - 2008 F150 1 06-20-2015 10:00 AM
Brake problems, need some help! HawaiianPSD 1999 - 2003 7.3L Power Stroke Diesel 8 10-11-2014 05:40 AM
Brakes-Soft Pedal... Dr-MorningWood 1987 - 1996 F150 & Larger F-Series Trucks 5 07-22-2014 02:38 PM
Brake Problems 85 F150 85AustinTucker 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-07-2014 11:06 AM
1999 F550 brake problem. need help bad. foot947 1999 to 2016 Super Duty 8 01-22-2013 05:04 PM
Tags
05, 1993, 95, brake, brakes, f150, f250, f350, floor, ford, pedal, proportion, started, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
