Well something is up with my truck's connector. I can't get my code reader to work with it. I've tried multiple different time's, new battery's nothing seems to work. I know the scanner works, I've used it on my mustang plenty of times and just for the hell of it I went to my friend's '89 mustang with it and it instantly worked.
I CAN get codes out of the truck using the paper clip method. I'd just would like to use my code reader since it's easier.
Try some contact cleaner in the plugs on the truck. While you have the plug wet, plug in the reader a few times. They crud up and give grief sometimes..
X2..I also have used a small screwdriver to scrape off the crud....
