2008 f150 dash swap
2008 f150 dash swap
I have a 2008 f150 xlt with a 4.6L
The dash that was in it was trash so we went to pick and pull and got a replacement from an 2004. Turns out everything is the same except the left turn signal switch plug (just switched out the switch works fine) , and the where the power wire for the obdll plugs in to the fuse box. No power to cigarette or obdll and fuse is fine.
The 04-08¹/² run to fuse 41
08¹/² on runs to fuse 110
any suggestions on how to get power to obdll.
Should I run a new wire from the fuse box to the 12v /obdll or other option.
Sully66
04-18-2018 07:00 PM
