spark plugs and triton engines - Ford Truck Enthusiasts Forums
Old 02-28-2009, 06:16 PM
ZonaNavyStar ZonaNavyStar is offline
ZonaNavyStar is starting off with a positive reputation.
Hey, I know there is a ton of information on here about the issue with the spark plugs in the triton motors throughout the years, but I was hoping someone could give me a paragraph synopsis of the whole issue. I was looking for a brief description of the problem, the years and engines typically affected, and what Ford has done to remedy the issue. Any other lingering issues surrounding this? Thanks
Old 02-28-2009, 07:46 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
The mod motor likes to eject spark plugs due to an insufficient # of spark plug threads
1992-2004 4.6 2v in the cars/suvs
1997-2004 4.6 2v in F-150 (2004 in old body style trucks only, not new body style truck)
1997-2003 5.4 2v
1997-2003 6.8
the 5.4 mod motor has very narrow passages surrounding the plugs inside the cylinder...this allows crap to accululate on the electrode and causes the spark plug to occasionally break
2004-2008 5.4 3v in F-150/Mark LT/Superduty/Econoline/Navigator/Expedition
the 4.6 3v and the 6.8 have been fixed so they no longer eject spark plugs
Old 02-28-2009, 08:50 PM
Catmonkey Catmonkey is offline
Catmonkey is starting off with a positive reputation.
Actually the plug for the 3v engines was revised in 2008 and resembles a traditional spark plug. It has at least an inch of threads so there no chance of the plug popping out of the head. Below is a pic of the revised 2008 plug (top) and the previous 3v that are breaking apart on removal.
Old 02-28-2009, 09:50 PM
Tylus's Avatar
about 1/2 the 2008 production run is the old style of plugs
but yes, the later 08's have the 09+ plug style
Old 03-04-2009, 10:48 AM
From what I've read, 5.4 3v engines with build dates (that's engine build date, not vehicle) after 10/8/07 got the new heads with revised plugs. The engine build date will be on the tag on the driver side valve cover.
Old 02-15-2011, 09:41 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
So,...can you use the "new" plug,..in the "old" head?
Old 02-16-2011, 12:15 AM
Fox Fader's Avatar
Fox Fader Fox Fader is offline
Fox Fader is starting off with a positive reputation.
Quote:
No.
10 char
Old 02-16-2011, 01:35 PM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
If this happens to you and it will. Lisle tool company has the best kit I have found to remove the broken electrode. The part number is 65600 and it is worth its weight in gold. But is only around $100 bucks.
Old 02-16-2011, 01:58 PM
jpurvis79bronco jpurvis79bronco is offline
jpurvis79bronco is starting off with a positive reputation.
...so are the early 08 4.6 2v effected with plug problems? I've got 32k on mine and would rather change them before I have a major problem.
Old 02-18-2011, 07:17 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
Quote:
At 32k is early for a plug change plus the early 4.6-2v's would blow the plugs out. I think that problem was corrected by '08
Old 02-19-2011, 02:32 PM
Good to know as I hope to get a lot of miles out of this truck. I just figured i'd change them before they seized, but that doesn't seem to problem. Anyone know if the plugs are different or just more threads on the head on the newer 4.6?
Old 02-19-2011, 05:03 PM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
New 3V plug on the top and old 3V plug on the bottom.
4.6 liter triton blowing spark plugs F-150fireman Modular V8 (4.6L, 5.4L) 1 04-10-2015 07:33 AM
2007 5.4 Triton Camwalk onewirenut New Member Introductions 2 08-26-2014 09:08 AM
2003 F250 Triton v8 5.4 L mbamiss Modular V8 (4.6L, 5.4L) 4 03-16-2012 07:27 PM
Updated sparkplugs in 08 ? UncleTom 2004 - 2008 F150 5 02-17-2011 05:24 AM
2005 F-150 Triton 5.4 Spark Plug TSB 5 Star 2004 - 2008 F150 1 08-26-2010 01:03 PM
Tags
2004, 46, 54, ejected, ejecting, engine, engines, expedition, expediton, f150, ford, plug, plugs, spark, triton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
