I put the truck on jacks and ran the 4.9L in gear to find my oil leak. I watched for leaks around the valve cover, oil pan, oil filter, sending unit, etc., but didn't see any leaks until I turned off the engine; then a couple of drops of engine oil ran outside down the middle of the rear plate assembly from the oil pan rear gasket area. Is it the oil pan rear gasket or the rear main, or something else?
