P0000 code
Old 02-27-2009, 09:31 PM
bigralso's Avatar
bigralso
bigralso is offline
P0000 code
F150 7700 XL 5.4 Triton Bi-Fuel. Just filled up the truck both gas and propane. What happened the 80% did not shut off and ended up putting about 20 litres more propane that it should have taken. As soon as I left the station I had a bucking bronco for a ride. was hoping it would stop after driving 100 km. It has not. but 3 codes came up first P0000 then P0301 cyldr 1 misfire detected and the P0000 for the 3rd one. my book does not show what P0000 is. Does anyone know what P0000 code is Tried a search but did not see what I was looking for.
Old 02-27-2009, 11:11 PM
bigralso's Avatar
bigralso
bigralso is offline
From what I have found so far there is no such code as P0000
Old 02-27-2009, 11:55 PM
Mawk's Avatar
Mawk
Mawk is offline
P0000
No Self Diagnostic Failure Indicated
It shouldn't have showed up in the scanner, and if it did, cylinder 1 misfire should not have shown. Perhaps try disconnecting the battery and taking it for a ride to see what comes back. If no self diagnostic failure is indicated, it shouldn't tell anything to the scanner except "no code" or "0" or something along those lines (depending on scanner type/model).
Old 03-01-2009, 02:56 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
If you had no issue before refueling, the over pressure in the propane tank set you up for a problem.
Release the pressure to normal levels and see if the problem goes away.
Your bi-fuel system is very complex and may have responded to the overpressure.
daddyzhome
3.8 & 4.2L V6
12-07-2014 05:44 PM
Volkskid
10-13-2014 09:25 PM
Lastwagen
6.7L Power Stroke Diesel
01-07-2014 07:34 AM
gsxr1300
08-12-2012 05:43 PM
cabo169
1983 - 2012 Ranger & B-Series
04-28-2009 06:54 PM
Quick Reply: P0000 code
