Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 02-27-2009, 09:31 PM
bigralso's Avatar
bigralso bigralso is offline
Garage is empty, add now
bigralso is starting off with a positive reputation.
P0000 code
F150 7700 XL 5.4 Triton Bi-Fuel. Just filled up the truck both gas and propane. What happened the 80% did not shut off and ended up putting about 20 litres more propane that it should have taken. As soon as I left the station I had a bucking bronco for a ride. was hoping it would stop after driving 100 km. It has not. but 3 codes came up first P0000 then P0301 cyldr 1 misfire detected and the P0000 for the 3rd one. my book does not show what P0000 is. Does anyone know what P0000 code is Tried a search but did not see what I was looking for.
  #2 (permalink)
Old 02-27-2009, 11:11 PM
bigralso's Avatar
From what I have found so far there is no such code as P0000
  #3 (permalink)
Old 02-27-2009, 11:55 PM
Mawk Mawk is offline
Mawk is starting off with a positive reputation.
P0000
No Self Diagnostic Failure Indicated
It shouldn't have showed up in the scanner, and if it did, cylinder 1 misfire should not have shown. Perhaps try disconnecting the battery and taking it for a ride to see what comes back. If no self diagnostic failure is indicated, it shouldn't tell anything to the scanner except "no code" or "0" or something along those lines (depending on scanner type/model).
  #4 (permalink)
Old 03-01-2009, 02:56 AM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
If you had no issue before refueling, the over pressure in the propane tank set you up for a problem.
Release the pressure to normal levels and see if the problem goes away.
Your bi-fuel system is very complex and may have responded to the overpressure.
Tags
0000, 2001, 2002, 2003, code, codes, diesel, f150, ford, lightning, p, p0000, p0301, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
