2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Forgot to connect Mass Air Flow connector - Whoops!
Old 02-27-2009, 11:34 AM
rbarbot2's Avatar
rbarbot2
rbarbot2 is offline
So, I changed my air filter yesterday.
Unfortunately, forgot to reconnect the Mass Air Flow connector before starting the engine. The Check Engine light and the "limp-mode" wrench lamp quickly came on to alert me that I had forgotten something. I reconnected the sensor and the wrench lamp went out but the check engine lamp is still on.
Am I going to need to get the lamp reset at the dealer? The manual indicates that the OBD-II sytem will clear some errors after 3 cold start cycles of driving the vehicle in mixed city/highway. Anyone have any thoughts on this?
Old 02-27-2009, 12:59 PM
function12's Avatar
function12
function12 is offline
Did you try disconnecting the battery for 5-10 minutes?
Old 02-27-2009, 03:45 PM
berry1234's Avatar
berry1234
berry1234 is offline
I was going to suggest disconnecting the battery too. Maybe 20 minutes.
Old 02-28-2009, 09:08 AM
gddyup's Avatar
gddyup
gddyup is offline
Depending on how that particular sensor is coded, something like that usually will go away after 3-5 key cycles of the ignition. The Batt trick works on soft codes that don't store, but hard codes will stay usually until the ECM sees the correct information after a certian number of key cycles or the hard code gets stored until it is cleared by a code scanner.
Old 03-02-2009, 01:28 PM
rbarbot2's Avatar
rbarbot2
rbarbot2 is offline
I avoided disconnecting the battery because I was curious whether the light would clear on it's own.
Good news:
After the 3rd morning of cold starting the vehicle, the Check Engine light went out.
Thanks for the tips.
FordLou
1997 - 2003 F150
12-11-2015 04:36 PM
leeg777
1997-2006 Expedition & Navigator
03-27-2007 06:56 PM
Dadzilla
1983 - 2012 Ranger & B-Series
08-23-2005 10:13 PM
blue93explorer
08-16-2004 06:05 PM
mcoop73
1997 - 2003 F150
03-18-2003 11:38 PM
Quick Reply: Forgot to connect Mass Air Flow connector - Whoops!
