Go Back   Ford Truck Enthusiasts Forums > General > General Automotive Discussion
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
General Automotive Discussion SPONSORED BY:
  #1 (permalink)
Old 02-27-2009, 09:40 AM
Ron1999 Ron1999 is offline
Garage is empty, add now
Ron1999 is starting off with a positive reputation.
Build Your Own Truck
We all have our own personal loyalties to certain brands, parts, makes, and models.
So, the question below is posted JUST FOR FUN.
Assuming that all parts could simply be connected without any adapters whatsoever (there is a Johnny Cash song running through my mind right now):
If you could build your own truck, using any parts from any manufacturer (regardless of make or model) what parts would you use, and why?
  #2 (permalink)
Old 02-27-2009, 11:43 AM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
Well I'm gonna start off by breaking party lines and go with a P-pumped Cummins 12 valve with a ZF-6 tranny, but mount it on a 97 Ford F-350 frame. High pinion D60 up front, with a D80 rearend. Then put a singlecab longbed with a flatbed on it. Mild 4'' lift 35'' boggers. The ultimate ranchtruck.
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles
Dr. Ron Paul 2012!!
  #3 (permalink)
Old 02-27-2009, 01:24 PM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
I would start with a 77 F-150 4x4. Add in a ford 427 medium riser, granny low 4 speed. Dana 44 in the front with a ford 9" in the rear.
__________________
2009 FORD RANGER fx4 off/road, 5-speed manual, torson diff and rancho's!
2008 mercury mariner 4x4 V-6, automatic.
1987 jeep wrangler, 258, 5-speed
  #4 (permalink)
Old 02-27-2009, 09:00 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to behold
Quote:
same parts but in my 70 F350 crew and a 205/203 doubler in it but with a regular 8 foot bed and a crew cab.
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed DD
SoCal FTE Member
  #5 (permalink)
Old 02-27-2009, 09:35 PM
Old93junk's Avatar
Old93junk Old93junk is online now
Old, tired and grouchy
1993 Ford F-250
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Sticking with ford here, how about a real Ranger GT, with early 90s mustang GT 5.0 5spd drive train, short bed 2wd with 4 wheel discs....Done cleanly as if it just left the factory.
__________________
93 F-250HD SC 460 E4OD
96 Explorer Limited 4.0 V-6 OHV
93 Ranger Splash 2.3 5spd only 51,000 miles!
84 Ranger 4x4 2.8 V-6 5spd......needs a new TK-5 trans, PM if you have one!
Dave
Oregon Assistant Chapter leader: To join the Oregon Chapter, click HERE
  #6 (permalink)
Old 02-27-2009, 11:08 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Well, you stole my engine and trans choices, but you can keep the frame. I'll stuff mine into a 70 F250 Sport Custom 4x4, but with a mated transfer case, crossover power steering, and D60s front and rear turning 36" Goodyear MT/Rs through selectable lockers. Receivers front and rear with Anderson connectors to handle 9-12k winches, and dual batteries with a large-frame 160amp alternator.
An actual stereo system integrated into the truck, and it's all set to go. Well, all set after a nice two-tone paint job with Boxwood Green below the trim, and Diamond Green above it.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #7 (permalink)
Old 02-28-2009, 03:58 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
My Ideal Truck would be A new F100:
4000lbs MAX Curb Weight +- options, 250Hp Direct injected V6, Reg Cab, Scab option With 6.5'-8' box. Payload in the 1500lb range, around 7500 towing. 6 speed auto & 6Speed man.
NO CREW CAB, If You want a commuter truck, Buy a 2009 6500 lb F150!
It's gotta have simple, comfortable seating, CC,PW,PL,PM,AC available.
A couple of useful gages.
Go back to 16" wheels, there's absolutely no need for anything larger.
Box rails low enough to reach over, while standing on the ground. So We won't need no stinking tailgate steps/side box steps just to use the box.
__________________
93 F One Fiddy- 5.0/AOD/3.55 250K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,BB Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #8 (permalink)
Old 02-28-2009, 05:17 AM
Another choice would be a new ranger 4x4 4 door supercab. Ford 300 I-6 and 6 speed manual trans. Dana 44 front, with 32 spline 8.8 in the rear with 4:10 gears and detroit locker. Factory high boy with 33x12.50 BFG AT KO's. Manual t-case and hubs.
__________________
  #9 (permalink)
Old 02-28-2009, 06:59 AM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
7.3 powerstroke and 6 speed allison automatic, on a custom built 4X4 frame, divorced transfer case, dana 60 front, dana 70 rear, 4 wheel disc brakes.
all of that covered by a 65 falcon 4 door rancheroo body.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #10 (permalink)
Old 02-28-2009, 10:23 AM
Quote:
didnt think so many of use would have the same idea almost...its making me want to go buy a dooner truck.
__________________
SoCal FTE Member
Tags
boxwood, build, cab, case, create, crew, divorced, f150, f250, ford, frame, green, make, ranger, search, transfer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
