Joe
What year truck is it for? 91 was a kingpin axle with slide pin caliper brakes. Our years are all balljoints but 94 still used the slide pin calipers. 95-97 has bolt on calipers. The 91 hub will fit any of the spindles but the rotor is about 1/4" smaller and you'll loose some surface area for the pads to work on.
