? Ford vs. Toyota ? - Ford Truck Enthusiasts Forums
? Ford vs. Toyota ?
Old 11-05-2002, 10:56 PM
Cybertaz126's Avatar
Cybertaz126 Cybertaz126 is offline
Cybertaz126 is starting off with a positive reputation.
? Ford vs. Toyota ?
Hey everybody,
I got a question . Theres a guy i know who has a Toyota Tacoma who is always braggin' on it. He swears he can hook up to me and drag my Bronco with the 4.9 I6 around. I'm pretty sure i could pull him around with no problem, but do ya'll think he could actually do it. i don't want to go out there and look like a idiot gettin' pulled around by a Toyota. I'm pretty sure i could beat him but i want to see what everybody says.
Thanks,
Cybertaz126
Old 11-05-2002, 10:59 PM
BucksCountyCountryBoy BucksCountyCountryBoy is offline
BucksCountyCountryBoy is starting off with a positive reputation.
? Ford vs. Toyota ?
[updated:LAST EDITED ON 06-Nov-02 AT 00:01 AM (EST)]A Tug-O-War??? Cool :-)
What's the weight differential and in who's favor? To my way of thinking the heavier beast would have a better than even shot...
Got Lead (plates)..? ~LOL~
Maybe I'm off base...
80 F250 Ranger 4X4 cab on 87 Chassis --
1984 351W - Mallory Uni-Lite, MSD wires, Offy intake, 600 Holley, K&N filter, Shorty headers - Dual Exhaust with twin Flowmaster 50's, C-6 trans, American Racing 767's 33x12.5x16.5 sneakers--
Alpine stereo with 400W Jensen Amp and 2 x 300 Watt "boom boxes" behind seat - 2 x 180 watt Xplod's in the doors..
Still workin' on it!
Old 11-05-2002, 11:02 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
? Ford vs. Toyota ?
Cybertaz, I think it will be a weight/traction issue. I'm certain the 300I6 will pull harder than a toyota. But if you don't have enough weight for your tires to bite, he will drag you backwards while all of your tires are spinning. Agree to the pull, but show up with about 1000 lbs of junk in the back of your truck. DF
Old 11-06-2002, 10:01 AM
Vampiro Vampiro is offline
Vampiro is starting off with a positive reputation.
? Ford vs. Toyota ?
put sandbags or cement blocks in the back of the bronco to add traction. the l6 is a torque engine. i think it'll pull ne toyota around
Old 11-06-2002, 10:10 AM
Graffe Graffe is offline
Graffe is starting off with a positive reputation.
? Ford vs. Toyota ?
Weight, Traction, and torque. That's what you need. The weight needs to be directly over the axles and you need traction to pull. If you are going to do this on pavement, then you need more surface area of rubber on the pavement, i.e. slicks. If you are doing this on the dirt, then you need an aggressive tire like a Super Swamper Bogger or something with a chevron pattern. In both cases, air-down your tires to make the contact patches larger. You'll rip the frame out from underneath that 'yota.
Graffe.
Old 11-06-2002, 10:39 AM
Yeti's Avatar
Yeti Yeti is offline
Yeti is starting off with a positive reputation.
? Ford vs. Toyota ?
Do it, just make sure you get pictures!! I love to see ripped up drive train pictures!!
Do these types of posts ever go anywhere? Seems there is always a lot of talk but it seems they never happen. :-X23
I say post pics then talk about it, theory is great, but I like real life expierences.
Just Do It
Old 11-06-2002, 02:54 PM
? Ford vs. Toyota ?
Thanks for ya'lls input . Now I belive i'll go teach this guy a lesson!
Cybertaz
Old 11-06-2002, 03:21 PM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
? Ford vs. Toyota ?
Yeah, just be careful on his truck. Remember, Toyotas are manufactured from recycled soup cans and junk aluminum. You'll twist his chassis up pretty good if he starts yankin' on the chain.
:-X12
The 300 I-6 is a torque monster. The Bronco is much heavier too. There is no way you shouldn't be able to pull him around like he's on a lawn mower.
Old 11-06-2002, 06:49 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
? Ford vs. Toyota ?
Well, he might have an advantage if it has a locker. Give yourself one, deflate your tires to about 15 psi before the pull.
Old 11-06-2002, 06:56 PM
mick460 mick460 is offline
mick460 is starting off with a positive reputation.
? Ford vs. Toyota ?
I can see it now both of them will be walking home. Oil and grease running out all over. Driveshafts that look like prezels. Man ain't life great.
Old 11-06-2002, 08:17 PM
? Ford vs. Toyota ?
I sure hope that don't happen . I like my driveshaft the way it is.I don't think he has a locker either.
Old 11-06-2002, 08:38 PM
4x4x4x4 4x4x4x4 is offline
4x4x4x4 is starting off with a positive reputation.
? Ford vs. Toyota ?
Has anyone ever noticed that the front grill of one of the newer
toy-ota (truck?) models looks like this .
It really does,seriously,it really does .
Old 11-06-2002, 08:43 PM
fordtruckin fordtruckin is offline
fordtruckin is starting off with a positive reputation.
? Ford vs. Toyota ?
Wow this sounds cool, be sure to let us know how bad you whup his butt. Just remember, lots of weight, air down and get the jump on him.
Old 11-06-2002, 11:30 PM
BuiltToughF250's Avatar
BuiltToughF250 BuiltToughF250 is offline
BuiltToughF250 is starting off with a positive reputation.
? Ford vs. Toyota ?
i was thinking--- you should "tell" him you are going to use four- high to get your speed up, just to make him think he should too.
then when he is losing power and gear ratio, your truck is already locked into four LOW to give you extra pulling power.
you might want to have a friend he trusts, pull up his parking brake alittle bit
BuiltToughF250
Old 11-07-2002, 09:00 AM
WXboy's Avatar
? Ford vs. Toyota ?
I can't believe you guys even think this is going to be a contest. We're talking about a Toyota Tacoma vs. a full-size Ford Bronco, right? I watched my brother destroy a Toyota in a pulling contest a few weeks ago...and my brother drives a V6 Chevy S10! This guy has a Bronco with a 300 cubic inch motor and lots more weight. This should not even be a contest. That toyota is toast.
In fact, I honestly would not be surprised if this guy could pull that toyota in 2-wheel-drive. No kidding.
Radiator Capacity? Cybertaz126 1987 - 1996 F150 & Larger F-Series Trucks 0 08-07-2006 03:16 PM
Should I Balance/Blueprint my 351W? Cybertaz126 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 01-15-2006 07:53 PM
I want your stock muffler... Cybertaz126 Exhaust Systems 5 09-17-2005 10:56 PM
Christmas Gag Gift's Cybertaz126 General NON-Automotive Conversation 29 12-11-2003 06:16 AM
Sub Box in Bronco? Cybertaz126 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 11 12-21-2002 09:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
