Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-26-2009, 02:42 PM
lew52's Avatar
lew52 lew52 is offline
lew52 is gaining momentum as a positive member of FTE.
Filling a nitrous bottle
I went to get my bottle filled & the guy gave my two choices... Frezze the bottle so it just sifones in .. or have it pumped in... They say its a cleaner fill if they dont use the pump.. Its the same price... What do you guys do ??? Lew
  #2 (permalink)
Old 02-27-2009, 01:39 PM
lew52's Avatar
Hey Lew... What up dude....Whats doing ??..If ya got the time just letem freeze it !!!
  #3 (permalink)
Old 03-01-2009, 09:07 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
Lew, I never ran nitros but want to in the near future.Whats it take to set it up and how much time can you shave off?
  #4 (permalink)
Old 03-02-2009, 06:52 AM
lew52's Avatar
Quote:
Ya it took some time to set it up..They dont make a spray bar set up for the truck intake...So we used a NOS universal kit & added an other nozzle because of the intake tube & duel throtle body...So were running two nozzles one in each tube... Starting at 50 shot.... Then going to bump it to 100 shot....Useing a RPM window swich so the nitrous will only come on at full throtle from 3000-6000...Have the rev limiter set at 6200... Shif at 5900...Also useing a MSD timing box so we can retard the timing from inside the truck with the turn of a knob...When we went to spray it we started to lose fuel pressure so we shut it down...So not sure how much it did...Now we have to upgrade the fuel system thats why i was asking you about the fuel pump...When we get it up & running i will let you know how it comes out...Lew
  #5 (permalink)
Old 03-02-2009, 08:23 PM
393STROKER's Avatar
I think I saw a kit that fits inbetween the upper /lower for Edeelbrock Performers
  #6 (permalink)
Old 03-03-2009, 06:48 AM
lew52's Avatar
Ya they make spray bars for the edelbrock...holley...trickflow....ect....But there all mustang manifolds...I have a edelbrock truck manifold...I have talked to the tech guys at edelbrock & NOS....& they say none of them will work on that manifold.. Lew
  #7 (permalink)
Old 03-03-2009, 12:22 PM
393STROKER's Avatar
Interchangeability
Yeah, I talked to that idiot about if they had a water pump for my truck and he said that they did not have any and the mustang one wouldn`t work,but I got one and it works.I went to the speed shop yesturday to get a gasket for the upper/lower for my truck and the guy said that he didn`t have it,so I told him to look-up one for a mustang.He said they were completly different because the part numbers were different.The number is different only because the extra gasket for the side case is different not the upper /lower.So the NOS Big Shot wet system should fit.Thats the problem I`ve been dealing w/since I started on my `90, everybody makes stuff for Mustangs but not the trucks but alot of it w/interchange.
  #8 (permalink)
Old 03-03-2009, 01:09 PM
lew52's Avatar
Ya i know what you mean...The mustangs are easy but the truck can be a pain...When it comes to parts.. The guy at edlbrock was good... I was on the phone with him for about 20 min while he got the mustang & truck manifold & tried different spray bars... The ports line up but one of the bolt holes dosnt...So i said i can just drill another hole but where the hole would be theres nothing there to drill..I would have to add on to the bar ....I did find out ...not 100% sure but the holley spray bar gasket lined up with the stock truck manifold..but not the edelbrock i have.. just that one hole is different...If you ever find one that will work let me know... Thanks Lew
  #9 (permalink)
Old 03-04-2009, 07:59 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is online now
1966Tbird is starting off with a positive reputation.
you could always put a gob of jb weld where you need the other bolt then sand it level with the spray bar and drill it out....i fill the bottom of the intake runners on blue thunder manifolds with jb weld for FE engines all the time and have yet to have it break loose, i also have used jb weld to repair a broken valve cover bolt flange on an FE intake with no problems just sanded drilled and tapped like it was metal
__________________
89 F-150 leveling kit 33x12.5 BFG All-Terrains, Trick Flow Fast as Cast Heads, Comp Cams Gold Roller Rockers, Edelbrock RPM Air Gap Intake, Trick Fuel 750 Mechanical Secondary Carb, MSD E-Curve Distributor, Comp Cams 280hr Roller Cam, Comp Cams Roller Lifters, Comp Cams Valve Springs, Trick Flow Pushrods, DSS Main Girdle, ARP Bolts, Cometic Gaskets, Forged Pistons, 125 Shot of Nitrous, AOD, 3500 TCI Stall Converter, Lentech Street Terminator Valvebody, 4.56 Gears, Flowtech Headers, 2.5in Exhaust
  #10 (permalink)
Old 03-05-2009, 06:44 AM
lew52's Avatar
That sounds interesting..I dont mind doing some fab work...Getting use to doing that...Im going to check into that a little more...If its only one hole that might work ...I would rather use the spray bar...
  #11 (permalink)
Old 03-05-2009, 02:22 PM
Crash! Crash! is offline
Crash! is starting off with a positive reputation.
Quote:
Nitrous is purchased by weight. Always use frozen bottles (most places have an exchange policy so you can take the cold one). ALWAYS weigh the bottle and verify you get the correct # of N2O. Add the weight you bought to the weight of the bottle.
__________________
http://img.photobucket.com/albums/v1...xter/00121.jpg
Un-Naturally aspirated 4.6 L 5-speed!
488/542 at the wheels!
  #12 (permalink)
Old 03-05-2009, 02:33 PM
lew52's Avatar
Ok.... The frezze is better... Our tank is painted the same color as the truck so we cant do an exchange...So we just drop the bottle off...Come back in a few hrs..& they fill it while were there...& check it on the scale...$4.00 a pound....Thanks... Lew
  #13 (permalink)
Old 03-20-2009, 01:10 AM
2000BLK54 2000BLK54 is offline
2000BLK54 is starting off with a positive reputation.
We don't freeze our bottles. Has caused problems with the valves and gauges in the past. 5-gallon bucket of ice water and Morton salt will chill a bottle plenty cold for filling. You'll do better to pay attention to purging the fill valve and line from the big tank if you are worried about getting every last bit into the bottle.
__________________
2000 F-150
SuperCab 5.4L, Flareside
S&B, Flowmaster SI/DO, T. Perfomance Dual Electric Fan Kit, ATI ProCharger P-1SC (12 psi), Snow Methanol injection, Jet-Hot full length headers, offroad exhaust
www.cardomain.com/id/2000blk54
  #14 (permalink)
Old 03-20-2009, 05:17 PM
lew52's Avatar
Quote:
Ok sounds good . They purge the line before filling..I dont have a bottle gauge i have a line that runs to an in dash gauge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
