Finally in epoxy primer!!!!!
Like a previous thread I am also building my own bed. I used 14 ga steel for mine which I'm sure added a lot of weight. I spent approximately $250 for the steel, but keep in mind I purchased the steel before prices went through the ceiling. I've got enough metal left to almost build another one. I wanted to build mine different enough that it made no sense to buy one of the manufactured ones and turn around and cut it up.
<!-- END TEMPLATE: postbit_onlinestatus -->
I had a sheet metal shop brake the angles in the side panels and welded the tubing to it paying attention to heat buildup. I built a 1" square framework and then welded the side panels to it.
I planned to make the stake pockets flow into a style feature at the back of the fender. Also wanted my roll pan to blend into this feature and end even with the bottom of the rear fenders.
I built two different roll pans, one with 4 fairly traditional looking bullet shaped glass lense lights and one that is still undecided on the type of lighting. The roll pans bolt in so I could actually run either one.
The wide angle has this looking a little distorted.
The tubs are a wide trailer fender cut in half and skirts welded in them to close them up inside the bed.
Trial run to see how my truck clearance lights will look as tail lights.
Finally a coat of epoxy primer and a little filler to smooth everything out and another coat of epoxy. Now I guess I'll try to figure out how I want the tailgate to look.
Andrew
Andrew
Andrew
The wheels and tires are my rollers that I always use on a project. I picked them up cheap over 30 years ago. I am big fan of the older wheels built in the 60's and 70's. I plan on running a set of American 200S wheels that I bought brand new in 1973. I'm not a very big fan of the new fad in wheels that calls for running jumbo diameter rims with what looks like rubber bands stretched on them for tires. Guess it's whatever floats your boat.
Thanks, I did a slight variation of a truck that won people's choice trophy at the Supernationals many years ago. The guy did a fantastic job of making everything flow together and not look like an afterthought.
You would be surprised at what you can do with a little direction. Nothing really special about anything I've done. My ideas don't always work out. Sometimes I'll come up with a design, sit down and make a cardboard mockup, cut it out in steel and weld it up, only to decide that it's only going to make a good paper weight. The roll pan and all the associated parts were initially done in cardboard and taped together on the bed before I cut the first piece of metal.
Sweet...
...Man that is just some sweet home-grown ingenuity!......
I especially like the "steel tubing to the angular part of the bed" trick...did you tack on the under side?
I am curious about the tubing though......
I couldn't get a clear look at the bench in your shop but caught a glimpse of a roller...what did ya need...?
You can P.M.me if need be...
GREAT WORK MAN...KEEP GOIN'...
You have to face your limitations. I know enough about the characteristics of metal that the phrase "bend me, shape me, anyway you want to" are more than just the lyrics of an old song.
So I must face reality when it comes to fabrication and add truth to the axiom that "a fool and his money is soon departed".
The tubing is just garden variety steel that you can buy at your local steel supplier. They have it in different wall thickness.
I picked up the slip roller from a local hot rodder that was moving out of state and didn't want to move it. It's old, but a lot better than some of the low buck units you see these days. I used it to roll the pan for the rear. But there are other ways to do the same thing, with stuff you probably have laying around your garage.
I'll post some more pictures if you would like of some of the smaller details.
