FIX ANY 6.OL LEAK By Wyatt66f100 - Page 2 - Ford Truck Enthusiasts Forums
Old 02-26-2009, 06:07 PM
PETE'S_6.0PSD PETE'S_6.0PSD is offline
PETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to all
great info Wyatt. reps to you .....
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
awesome post wyatt...rep to you
Old 02-26-2009, 09:35 PM
LionFan's Avatar
LionFan LionFan is offline
LionFan is starting off with a positive reputation.
Excellent info, reps to you
Old 02-27-2009, 01:30 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
Rep added.
Old 03-19-2009, 09:22 AM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
Bump ttt
10cl...
Old 03-19-2009, 05:10 PM
FlyCanadianGuy FlyCanadianGuy is offline
FlyCanadianGuy is starting off with a positive reputation.
Wicked Post, rep to you
Old 03-19-2009, 06:50 PM
mxer0022's Avatar
mxer0022 mxer0022 is offline
mxer0022 is gaining momentum as a positive member of FTE.mxer0022 is gaining momentum as a positive member of FTE.
gotcha covered with reps!
Old 03-19-2009, 07:43 PM
Nice Work Truck's Avatar
Nice Work Truck Nice Work Truck is online now
Nice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to beholdNice Work Truck is a splendid one to behold
Nice job, rep sent
Old 04-20-2009, 06:41 PM
03250sil 03250sil is offline
03250sil is starting off with a positive reputation.
early 03 250 xlt cc lwb 4x4 stock 6.0
i have a leak that is on the rear passenger side that falls from a tab on block at the bottom of the cylinder head at the stacked metal gasket next to the engine heater above the starter. the sides of both exhaust manifolds are dry and clean. november just had egr cooler replaced, last week icp sensor and lower turbo drain tube o rings replaced. the aluminum rear cover is clean as a whistle. i would guess that if it were the upper oil pump or the ipr the techs would have seen it when the icp was replaced. any other upper common leaks. not real bad but i don't like the oil in the drive way of the homes i have to visit
Old 05-10-2009, 06:51 PM
Wyatt66f100's Avatar
Wyatt66f100 Wyatt66f100 is offline
Wyatt66f100 has a good reputation on FTE.Wyatt66f100 has a good reputation on FTE.
Leaky head gasket maybe. id need to see it but thats my guess. ford hasnt had a problem with this actual engine, its the head bolt design. it wont contain the combustion pressures and will stretch the bolt from the head lifting off of the block. so could be a slight leak there. or from the rear of that side valve cover gasket. this is an uncommon leak. better to have it diagnosed by a tech then wonder what it could be. hope this helps
Old 06-06-2009, 08:09 PM
horofino's Avatar
horofino horofino is offline
horofino is starting off with a positive reputation.
Wyatt just wanted you to know another has found your post very useful, new to PSD world and wtin '04 X just got crank seal, cam sensor, idc?, and another EGR replaced all under PSD warranty. Bought X May 09 with 77K and put another 2100 miles on it in 2 weeks, all highway driving averaging about 72-78mph X had sat on lot since Nov is normal?
Old 06-07-2009, 05:55 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
HeavyAssault is gaining momentum as a positive member of FTE.HeavyAssault is gaining momentum as a positive member of FTE.
Quote:
C. CAC Tube Adaptors (Charged Air Cooler)- these are all the blue tubes going to your turbo and the air cooler and the intake manifold. there is a total of four of them. One is an elbow going to your turbo, the second one is the one that goes to your intake manifold from the tube that comes from the drivers side. third is the one between the air cooler and the drivers side CAC Tube, located down a bit from your air box. and the fourth one is on the exact opposite side from the third, follow the tube from your turbo and you will find it. the way you check these is you put a glove on and run your hand uder them and look at your hand. if there is oil on your had then its time for new CAC Tube Adaptors.
This isn't really an oil leak, it's a byproduct of the CCV system on these motors. A CCV reroute will help prevent any future "leaking oil" from these boots. New boots are not required if you clean the orginial boots and the areas they attach to with a good degreaser. IF you begin having boots blow off under pressure, replacing them is an option but the surface areas need to be clean of the oil to ensure a proper seal.
  #28
Old 06-07-2009, 12:12 PM
Quote:
sure you could do that. its just the orange stuff inside the CAC tube adaptors acts like a sealent. usally when they leak that means that the seal is failing enough for oil to leak through. not enough to loose pressure because the area that is leaking is pushing oil not air so you dont lose pressure. but if they get bad enoght yes, they can blow off. you may get a feel good seal if you clean it but the orange sealent on the inside is still the old leaking sealent. now is just has to form fit to a different rotated position if this is done. thus making the seal a little tempermental. sometimes it seals better sometimes it doesnt. i dont usually replace them unless they are leaking because if you in the middle of a tear down whats the point if they arent? the orange sealent inside is still doing its job and hasnt deteriorated yet.
thats good thinking tho. people could do that if they felt like it.
  #29
Old 06-07-2009, 12:38 PM
Your post said this was an oil leak, 95% of your discussion is correct. For the IC boots their function is to attach the boots tubes to the IC. There is no "oil seal" to fail on the inside of the CAC boots. The reason for the appearance of oil is directly related to the CCV system.
To just go replace the boots WILL NOT prevent the oil from coming back. The CCV reroute and a good cleaning of all the areas and componements is the ONLY way to ensure that oil will not appear again.
  #30
Old 06-08-2009, 08:46 PM
absolutly that will prevent it from happening. And at this point you can believe what you want about whatever you want its your truck. i dont even have one i just work on them all day everyday. im not trying to be smart im just saying its your truck do what you want. thats what makes these trucks fun. upgrades, mods, ect. some good for the trucks some bad. anyways yeah that will work too.
New truck and engine build DarkStarMedia 6.0L Power Stroke Diesel 12 11-24-2016 12:03 AM
Would dealer update latest PCM strategy on engine pull? diesel_dan 6.0L Power Stroke Diesel 11 04-26-2016 11:21 AM
Oil Leak at Bell Housing Kdawg89 6.0L Power Stroke Diesel 10 03-04-2016 06:15 PM
Having some real bad luck here psu927 6.0L Power Stroke Diesel 5 11-20-2015 10:10 AM
Troubleshooting a No-Start condition bismic 6.0L Power Stroke Diesel 76 09-01-2015 05:05 PM
Tags
60, 60l, cac, called, crankshaft, diesel, engine, ford, fords, front, leak, leakers, leaks, oil, psd, replacing, seal, top, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
