Front axle decode...... - Ford Truck Enthusiasts Forums
Old 02-25-2009, 12:51 PM
cgfirefighter's Avatar
cgfirefighter cgfirefighter is offline
cgfirefighter is starting off with a positive reputation.
Hi guys,
I was wondering if somebody could help me decode my front axle. The numbers on the plate are....
3 50 D8TA TE
610049-5
Thanks for the help.
Old 02-25-2009, 02:07 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
3.50 open axle, '78 truck production
BOM: 610049-5 was for a 1978 Ford 1/2 ton pickup with a part-time transfer case.
Old 02-25-2009, 11:09 PM
So I would assume it is a Dana 44 then???
Old 02-26-2009, 12:43 AM
Quote:
Yes.......
front axle decode David Greenhalgh 1987 - 1996 F150 & Larger F-Series Trucks 13 01-07-2016 05:54 PM
1965 F100 VIN DECODE daydo17 1961 - 1966 F-100 & Larger F-Series Trucks 4 10-01-2013 10:17 AM
Help decoding this front axle tag (numberdummy) benmoderow 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-05-2009 07:55 PM
Decode Help for a Dana Axle addixionz 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-30-2009 11:02 AM
need help with 9" axle tag decode STGFordCrazy04 Clutch, Transmission, Differential, Axle & Transfer Case 9 08-31-2005 08:26 PM
Tags
1978, 350, 4x4, 50, 6100495, axle, bom, d8ta, dana, decoder, decoding, ford, front, numbers, te
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
