Go Back   Ford Truck Enthusiasts Forums > General > The Next Generation
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The Next Generation For those ages 15-25.
Is F-150 Still King?
  #1 (permalink)
Old 02-25-2009, 11:19 AM
mstiles19's Avatar
mstiles19 mstiles19 is offline
mstiles19 is starting off with a positive reputation.
gloves
since there is a boots and jeans thread i think i will start a gloves thread.
i just get the heavy duty gloves that they sell at tractor supply. they work alright but i seem to destroy them in about a month.
where do you guys get your gloves and what kind? how to they hold up?
__________________
Matt
2001 5.4L F-250 SuperDuty
1989 jeep wrangler
VIDEO OF MY BACKYARD
  #2 (permalink)
Old 02-25-2009, 10:56 PM
4020FarmBoy's Avatar
4020FarmBoy 4020FarmBoy is offline
4020FarmBoy is starting off with a positive reputation.
For winter, fleece lined cowhide or lined jersey gloves with nitrile gloves under them works wonders. In the summer, i used to bale in mechanics gloves but i would wear them through in a week now i just go bare handed. If i do use gloves in the summer to grease equipment they are the gray leather with red and blue cloth. Get em packed with enough grease and they are water resistant and last forever.
Get my gloves at Rural King.
__________________
Ol' Blue 1995 F250 XL Reg Cab 4x4 351W 5spd 4.10LS Farm Truck
1988 F250 XLT Reg Cab 4x4 351W C6 auto 4.10LS Wood Gopher, Beater, Rough Truck
  #3 (permalink)
Old 02-25-2009, 11:10 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 is gaining momentum as a positive member of FTE. Dean88 is gaining momentum as a positive member of FTE.
Bein is I work at tractor supply part time, I also get my gloves at there. The heavy duty leather's can last me almost 6 weeks before fencing kills them off.
__________________
1992 F250 351W E4OD 3.55 Sterling
1988 F250 7.3 C6/underoverdrive 4.10 D70
1980 F100 300 3spd 2.73
1987 F150 302 T18 4.10 (RIP)
American by birth, Southern by the grace of God, Libertarian by choice!!!
  #4 (permalink)
Old 02-25-2009, 11:11 PM
dcf4x4's Avatar
dcf4x4 dcf4x4 is offline
dcf4x4 is gaining momentum as a positive member of FTE. dcf4x4 is gaining momentum as a positive member of FTE.
Summer gloves are Firm Grip gloves that Home Depot sells ($12, I think). Fairly cheap and last about a month of high tensile fence install (post and wire handling). Obviously the high contact points (finger pads) wear through after two weeks. I cut off the fingers once the holes become a hassle and then switch to new ones after I get enough splinters or wire punctures. For winter work I used to just wear some good old brown jerseys under these.
This past October I decided to splurge and I bought a pair of insulated and waterproof Iron Clads ($26.50). Expensive but fantastic. I purchased supposedly the correct size of XL but they were very tight. I got used to it after awhile. I certainly wouldn't be able to pick up any change but I could almost grab fence staples. They kept my hands warm as long as I flexed them once in awhile. They lasted for two months before I started to notice cracks in the fingers along the seams. The plastic liner started to show through.
I almost always wear gloves. With all the metal pointy stuff and rough wood it's just smarter.
Depending on this years economy I might just stick with the Iron Clads. It's simply a better product.
__________________
Dan
1994 Bronco XLT, 5.0, 5 spd (rust magnet)
2000 F350 Lariat, 4x4, 7.3, Crew, 6 spd, dually
(gauges, BD turbo, hpx line, 6 pos. chip, 6637, turbo back 4" Silverline, 295/75R16 w/ 2" spacer, '05 front end)
  #5 (permalink)
Old 03-07-2009, 06:02 AM
purecountry's Avatar
purecountry purecountry is offline
purecountry is starting off with a positive reputation.
I wear mechanics impact gloves when I'm working on my truck and its still hot. Otherwise I go barehanded, Ive worked fields, baling hay, and plweing the old way with a draft team and a turning plow, or whatever I needed. Als o did horse logging, and mechanics, along with a bunch of other stuff. I was raised to preserve the old traditions. Did a lot of forge work with no gloves too. Work enough and your hands get so tough gloves no longer matter. Most splinters and briars can't even pierce my skin on my hands now.
__________________
STG's Minions:Half-ton Hero
USMC AIRWING
You can run but you cant..........
Oh hell you cant even run.
  #6 (permalink)
Old 03-07-2009, 08:42 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
of RiffRaff
7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE.
Typically I don't wear gloves. Only when I'm welding, working on barbed wire fence, or handing hot/sharp metal.
For most all other stuff I go bare handed.
I get whatever gloves are cheap since I typically lose them before I wear them out.
__________________
-Pete, PAA member #84
99.5 F350 XLT 4x4 regular cab longbed 7.3L PowerStroke 4" MBRP turbo-back, Isspros, 6637 w/ cover, CCV, AIH delete, foil delete, 6.0 IC, Van turbo, RDP IC boots, DP Tuner
Smoke Responsibly
  #7 (permalink)
Old 03-09-2009, 05:28 PM
Ford Major's Avatar
Ford Major Ford Major is offline
Ford Major is starting off with a positive reputation.
Quote:
What brands do you get? I killed off a pair of Nighthawks and a pair Carhartts in 4 days of fencing and will go through several more pairs during the hay season, so I am looking for more durable types. Cost is not an issue, my dad works at a hardware store so I can get a good price on any brand.
  #8 (permalink)
Old 03-09-2009, 07:22 PM
rambuck's Avatar
rambuck rambuck is offline
rambuck is starting off with a positive reputation.
Typically I use jersey gloves from TSC, especially when I am stackin hay, partly cuz I am allergic. If I am doing heavier work like fencing, I go with some nice leather gloves with full grain.
  #9 (permalink)
Old 03-10-2009, 08:29 AM
WhëëlMå1's Avatar
WhëëlMå1 WhëëlMå1 is offline
WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of
Carhartt makes somes of the most comfortable gloves Ive ever worn. I use them when splitting cords of wood, and its a godsend. So many out there use very rigid fabric, or dont seam around the joints well. I will have to look for a part number on em... I need some new ones. I always tear up the left hand way before the right (holding the log with that hand).
__________________
Rich
FTE Guidelines
Support American Manufacturing!
"The next time some actor or rock star tells you what to think, tell them to **** off." - Dennis DeYoung
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
