How much paint??
If I were you I would buy a gallon, just to be sure, but it's possible to get by with 2 quarts, 3 is common on a longbed.
However, with that particular color I would assume it needs a basecoat of white or silver and then a top coat of the orange and then your clear.
So, 1 quart each of your primer
3 quarts white
3 quarts orange
and then clearcoat system
What is the brand of that paint?
3 quarts white
3 quarts orange
3 quarts white
3 quarts orange
3 quarts white
3 quarts orange
Item Detail
If the project isn't going to take off for a while, you can pick-up the paint and supplies as you go. I personally have never heard of Kustom Shop paint, but can add I have painted with Dupont which is very high quality and even Rustoleum which even that stuff turns out well.
Josh
Not only that, but he may have enough of the thinners, reducers and primers already. You would just need to gather the basecoat. I would ask for some more opinions on whether that color can be sprayed over primer or if it needs a base of white (which would help make it "pop" where a base of orange or yellow might darken it a bit) as well.
