poor fuel milage
poor fuel milage
hey guys i was wondering if any of yall had any reasons for poor fuel mileage im only getting like 12.5. i have a 1994 f-250 4wd 7.3 IDIT 134,500 miles new tranny....i bought this truck about 3 weeks ago....i thought that i would be getting better mileage than 12.5 any clues? please let me know....i have installed a k&n drop it air filter 1 week ago so the air filter is good and also added some Diesel kleen to the fuel to clean the injectors.
Fuel Mileage
Is that city or highway driving? I have a '93 4x4 Crew Cab Long Bed 7.3 IDI with a Garrett Turbo and I get about 11-13 on a normal day (winter though too), In the sumer I ususally get 13-15 city and the best I've had is 19 highway. These diesels are better than gas engines, but it's still a 7000 lbs truck and you cant really expect good fuel mileage. If its highway you might have a bad injector or somethin, but if its town, thats about what mine is gettin.
Idi
yeah, my bad. my truck is 5800 lol. only 1200 lbs off. Do you have large tires or anything? I have the stock tire size and no lift. I only get 9-11 if I drive like I normally do, but I have a new engine too and it's not broken in, so no pedal to the metal fro now. But yeah, get your exhaust system checked out or look at it yourself too. I had an '02 escape that got 11 in town and I had a bad cat. converter and my mileage dropped to 9 mpg.
you can look on the inside of the driver side door and it should tell you what gears you've got in the rear. it sounds like you have 3.55 gears?
ive got the same truck with about the same milage and i average 15-17mpg. I think you should be getting at the least 14-15mpg.
how much does it smoke under heavy acceleration?
im not surprised, the truck was in a accident while towing a goose neck trailer before i bought it so alot of crap was changed out and fixed.
sooo, im running 4.15s?
4.10 gears with E4OD at 2200 RPM should be going 70 MPH if it has 235/85-16 tires on it.
Same truck, same tires with 3.55 gears would turn 1900 RPM at 70 MPH.
So if your reading are much different, speedo error would add a couple MPG.
When the fuel goes from winter fuel to summer fuel, you will gain a MPG or two also.
Diesel 4x4 truck under 7000 pounds, I find that hard to believe.
Two wheel drive, a bit over 6000 I would go for.
Mine is right at 8000 pounds on certified scales full of fuel and me not in it.
Yes mine is a bit heavier with the dump flatbed, but not that much heavier.
8800 GVW - 3/4 ton (1500 Lbs) = 7100 empty weight
