anyone ever heard of putting a 3.8 liter into 4.2 liter engine bay
i have a 1997 F-150 with a bad 4.2 cant find a good used engine for under 600! I talked to a man at a salvage yard he said you can swap a 3.8 mustang in its place all you have to do is change the intake timing cover and flywheel and exhaust manifolds. i found one for 500 thats why i ask
I had a 4.2 with a 5 spd regular cab and it was kind of a dog, a 3.8 (I'm guessing auto) would have to be even worse. Plus you'll probably be getting on the gas more to make up for it, and decrease MPG.
just finished this exact swap. got a 2004 mustang 3.8 for $350. all I used from the 3.8 was the block, heads, valve covers, timing cover, and oil pan. evrything else was swapped from the 4.2. all in all I have about $450 in the swap, plus the $500 for the 97 F150 with a bown motor (mint body). so less then $1000 for a truck with 65,000 miles (on motor).
I did it cause the only 4.2 under $1000 had 214,000 miles. I got a 04 motor with 1/4 the miles for $350. no real cost difference between using either one aside from cost of motor. all the stuff I had to buy would have been usedon either motors. oil, antifreeze, upper and lower intake gaskets, just the usual stuff.
