1999 Ford Expedition (5.4) is hard starting - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-23-2009, 09:06 AM
rpstrickland rpstrickland is offline
rpstrickland is starting off with a positive reputation.
I have a 1999 Ford Expedition (5.4) and it is hard to start not all the time but I would say one in 10 times. When it does it I tune off the key and listen for the fuel pump to whine sometimes I cant here it and it will not start. I tune the key off and on and try to hear the pump sometimes I can other times I cant. The truck has 92,000 miles on it. If it would just fail it would be easy. Just don't want to strand my wife.
Old 02-23-2009, 09:27 AM
jb1390 jb1390 is offline
jb1390 is starting off with a positive reputation.
I would replace the fuel pump relay to start. If the relay doesn't close, no power to the fuel pump, meaning no start. A relay can start to go bad without completely failing at first if the contacts inside start to wear out.
Old 02-23-2009, 02:48 PM
HArd Starting
Where is the relay located?
1999 Expy start problem (newbie) Senor Joseph 1997-2006 Expedition & Navigator 4 04-15-2015 03:03 PM
2000 Expedition starting problem maxine 1997-2006 Expedition & Navigator 1 09-30-2012 01:46 AM
starting problems and P1405 hooked2 1997-2006 Expedition & Navigator 2 01-29-2012 06:24 PM
Zero fuel pressure, key on, runs OK?? rv8riveter Modular V8 (4.6L, 5.4L) 2 08-07-2011 12:33 AM
97 Expedition Tune Up RevJimmy 1997-2006 Expedition & Navigator 2 01-28-2002 03:58 PM
Tags
01, 1997, 1999, 2003, 54, change, expedition, f150, ford, fuel, hard, navigator, pump, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
