Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 07-04-2009, 07:16 PM
DCRB DCRB is offline
DCRB is starting off with a positive reputation.
dang so much information in this thread!! it's also nice to see people having an inteligent conversation as apposed to arguing about what's rice and what not... lol coughhondatechcough. any ways so the more you guys post in here the more confident i get. just to clarify a few things though, do i have to replace ALL of my o rings if I'm repairing and converting from r12-r134a? my friend just got a 30 gallon compressor so i might attempt to tackle this myself.
__________________
93 3.0l xlt extended aerostar
mods: 800 watt sound system. - 2" catback exhaust w new flexpipe and cherry bomb muffler. - 4g alt. wiring - Gutted stock airbox.
"88 civic "STD PLUS!!"
  #47 (permalink)
Old 07-04-2009, 07:27 PM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
Quote:
The short answer is YES.
It doesn't have anything to do with compatibility, though. The newest R12 system is now 16 years old, and so are the orings. It only takes one of them to fail next month to ruin your day. For about $10, it's cheap insurance against future leaks. Although the old BNR (black) orings are fine with R134a, the new HBNR (green) orings seal a bit better.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #48 (permalink)
Old 07-04-2009, 07:36 PM
huh i heard the same thing about my civic (i am also putting an ac system BACK into my civic. god why do people take these things out in the first place??)
__________________
  #49 (permalink)
Old 07-04-2009, 08:23 PM
Aww, you don't need all of that old, expensive, hard to fix AC crap in the way and adding weight. I'll bet the PO got .001 more horsepower when he took it off.
__________________
  #50 (permalink)
Old 07-04-2009, 09:04 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
When you refer to the "green" O-rings, are you talking about the opaque, light green, or the near-transparent bright green? I've seen them both in the yards.
  #51 (permalink)
Old 07-31-2009, 05:35 AM
I'm about to tackle flushing and servicing my dual AC system, and have a couple of questions.
First, if I stay with R12 type refrigerant, what type of orifice tube should I be using in the front and back? Both the brown colored version?
Second, I'm almost certain I have to replace my compressor; it definitely made some grinding type noises the last time I heard it run. How do I identify the FX-15 vs FS-10 compressors? Do they have different stamping numbers on them?
  #52 (permalink)
Old 08-01-2009, 01:06 AM
Afireinside2285 Afireinside2285 is offline
Afireinside2285 is starting off with a positive reputation.
I believe orange is the correct orrifice tube for R-12.
Good luck
  #53 (permalink)
Old 08-01-2009, 01:43 AM
I spoke to someone at Arizona Mobile Air today, who told me the correct front orifice tube is red; their PN 31-50003. So now I'm confused.
Unfortunately, he could not tell me how to identify the different types of compressors, and the "expert" was not available at the time.
  #54 (permalink)
Old 08-01-2009, 11:55 AM
The napa cataloging for mine was the orange one and the a/c has been working good since early spring when I replaced a ton of a/c stuff.I have a thread with tons of great info. floating around this board.I can find you the part # if you need.Also I wouldn't be surprised if different manufactures call for diff. colors who knows?
Good luck
  #55 (permalink)
Old 08-01-2009, 01:38 PM
Quote:
bah i don't need power i need comfort!! lol
__________________
  #56 (permalink)
Old 08-01-2009, 06:08 PM
Quote:
Good luck
I was wondering if the color codes were universal among the different makers. Also, is you system R12 or converted to R134?
  #57 (permalink)
Old 08-01-2009, 08:23 PM
CarCrazy1001's Avatar
CarCrazy1001 CarCrazy1001 is offline
CarCrazy1001 is starting off with a positive reputation.
Quote:
I'm not sure how to tell the difference between those 2 compressors, but try giving a call to 1-800-radiator. If u can't get an answer just replace the compressor for a new FS-10.
  #58 (permalink)
Old 08-02-2009, 12:41 AM
Quote:
I can tell them apart by looking, but I can't describe what is different between the two. They just "look" a bit different.
Any good replacement compressor will be an FS-10. I don't know of any reputable rebuilder that will even offer an FX-15.
__________________
  #59 (permalink)
Old 08-02-2009, 12:54 AM
Yes, the color codes are universal. Here's a list:
http://www.autoacforum.com/messagevi...threadid=10818
Ford bounced around between the orange and red otubes on the Aerostar dual systems trying for better performance from the rear unit. The rear Aero units were marginal at best when new. I generally use the red tube in them.
That is definately one system that doesn't convert well to R134a. Those systems struggled even with R12 due to the small condenser and the use of a fixed orifice instead of an expansion valve.
__________________
  #60 (permalink)
Old 08-02-2009, 01:25 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
xlt,
depending on your driving conditions, you may want to research VOV aka automatic adjusting orifice tubes, avail from RockAuto and other auto a/c parts supplies.
http://www.imcool.com/articles/aircondition/VOV1.htm
Tags
134a , ac , adapters , aerostar , auto , damage , fluorescent , ford , low , male , nipple , pressure , reading , repair , side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
