I Have p0470 exhaust presure sensor and P0478 Exhaust presure control valve high Tube i check is clean on koer test P0476 and P1711 this code maybe cold engine Thank you Adam
OK, I get the code info, but (not to be rude) could you write that in english that I can understand? Distinct sentences explaining when you get each of the code(s), what you've tried, and what your symptoms are would be very helpful.
I came from poland six years ago so im not typing perfect english sorry its a problem for you but i have two truck E-350 .Any symptons just this couple codes Thank YOU
Yes i think is clean about holes im not sure this sensor cost 120$ in dealer, so I wont be sure before I buy. Tomorow I gone change Good Ebp sensor from my other truck and i pull codes.
I remove the tube 2 days ago tube been clean.What this mean P0478,IF i have links on exhaust system this give this efect.I now this problem casue my High MPG.
Welcome! Both to FTE & the U.S.! We'll just have to make it work, now won't we?
Changing with a known-good part is perfect!
Like Jim said, make sure there are no holes in the tube. It's not very hard to remove.
Is the van not running very good? Rough idle or anything? Poor mileage?
Let us know what you find.
Also, we have some sponsors that might be able to get you a better price, if you can wait for the part to get shipped to you. Every little bit helps, right?
This van running perfect only I think its some emision inside the cab I feel snoopy when im driving this truck. This truck its 2000 E-350 has 160 k miles its not much I think on 33or 35 galon tank i can drive 400- 500 miles. ON my old truck 95 powerstroke e-350 I do it 700 miles on same tank .Four months ago I sold this truck NOw i have two Truck 2000 and 2001.I thinking take same milage its posible like on old one. Thank you
Adam If I had to guess I would say that your EBPV is not working. Take the good one from the other truck amd see what happens. Mske sure you check the old sensor for blockage though.
<TABLE cellSpacing=0 cellPadding=0 width="80%" align=center border=0><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="HEIGHT: 12.75pt" height=17>P047</TD><TD> Exhaust Pressure Control Valve High Input
</TD></TR></TBODY></TABLE>
Im thinking maybe he's talking about an exhaust leak,"I think its some emision inside of cab I feel sloopy when im driving this truck",could we be talking about uppipes(do vans have uppipes?)He's talking about fuel milage,and seemingly smells,right?
Phil
Phil
Yes they do have up-pipes, right in front of the inside removable cover. Dan (kwikkordead) posted a picture a while back of leaking up pipes on a van. He referred to it as the babys but in that thread.
Don't know if that would throw an EBP code, but he'll be able to fix a leak there easier than the rest of us can with the van access from the inside.
